 Post subject: Mini Starter
 Post Posted: Wed Nov 10, 2010 8:29 pm
Hey Guys, I have had some trouble with my mini-starter in the past. The problem is getting the correct gear to gear mesh without the gear sticking in the flywheel after it starts or being too loose and eating up the flywheel. I just got a CVR starter and another new flexplate SFI of course. I do not want this starter and flywheel to end up like the other one. I have the instruction sheet but am having trouble setting it up. I guess maybe I need a specific type of feeler gauge for this? It says to check the backlash 10-30 thousands and the gear should be between 40-100 thousands from the flywheel before engaging the starter. Does this sound right?
 Post subject: Re: Mini Starter
 Post Posted: Wed Nov 10, 2010 8:46 pm
Paper clip always worked for me #-o
 Post Posted: Wed Nov 10, 2010 8:56 pm
Paperclip between the teeth? I had hear that but don't know the method exactly...How Should it be done?
 Post Posted: Thu Nov 11, 2010 5:37 am
I pull the drive all the way out with a pair of pliers and then if you can fit the wire in between the teeth your good. You may have to turn the flywheel a touch to get it to slide out..
 Post Posted: Sun Nov 14, 2010 8:04 am
Same as barry i use the bigger paper clip it's about .060 dia.
Mike
Users browsing this forum: Google [Bot] and 7 guests
