 Post Posted: Wed Mar 24, 2010 9:15 pm
It's getting close to being out of the machine shop, I'd like to here what you guys think it'll make, I'm probably not going to Dyno it, but will be running it in a 68 tube chassis ladder bar car that weighs 2750 lbs with me in it at the starting line. It has 4.56 gears, powerglide, 14X32's
It ran 9.50's with a mild 496 iron heads Team G 1050 carb .708 lift dur @ .050 268/272 110 Lobe Sep
The new engine is a 555
Dart Big M tall deck
4.560 bore 4.250 stroke
14.8 compression
Comp Cam CB475 1828B/405/R 114
Dur @ .050 281/302 lift .824/.782 Lift
Int CL 112 Installed @ 110
Lobe Separation 114
BB2 Xtras ported by Havier Deleon
Tested @ 28"
Brodix BB2Xtra Cyl #5
..Lift.........CCFM Int.......CCFM Exh.......ACFM Int.......ACFM Exh.......CCFM Exh % of Int
0.050...........42.4................36.5...........42.0................36.4....................86.1%
0.100...........84.7................73.0...........84.0................72.8....................86.2%
0.150.........124.1..............106.8.........123.2..............106.6....................86.1%
0.200.........163.4..............140.4.........162.2..............140.1....................85.9%
0.250.........197.5..............159.2.........196.1..............159.3....................80.6%
0.300.........231.1..............177.9.........229.6..............178.5....................77.0%
0.350.........263.2..............193.5.........261.7..............194.7....................73.5%
0.400.........295.3..............208.6.........293.7..............210.5....................70.6%
0.450.........321.6..............224.2.........320.1..............227.0....................69.7%
0.500.........347.7..............239.9.........346.3..............243.6....................69.0%
0.550.........370.9..............253.8.........369.7..............258.5....................68.4%
0.600.........393.6..............267.7.........392.7..............273.3....................68.0%
0.650.........407.8..............278.8.........407.0..............285.8....................68.4%
0.700.........421.8..............289.8.........421.1..............298.2....................68.7%
0.750.........426.4..............299.1.........425.8..............308.4....................70.1%
0.800.........429.9..............308.4.........429.4..............319.6....................71.7%
0.850.........422.4..............316.2.........422.3..............327.4....................74.9%
0.900.........421.5..............323.8.........421.2..............336.0....................76.8%
Intake is a Super Victor
Carb is a 1050 8896 converted to 2 circuit
Digital Programmable 7 with Crank Trigger
Star Vacuum Pump
I'd like opinions of HP @ RPM and an estimate on ET and MPH for 1/4 mile and 1/8 mile.
Looking forward to your input,
Thanks
 Post Posted: Thu Mar 25, 2010 4:39 am
It will need a bigger carb =;
 Post Posted: Thu Mar 25, 2010 8:24 am
Now that's funny! =;
I'm planning on a bigger carb a little later, and I would be real happy with anything close to what Barry's car is running.
My original goal when I started gathering parts was to be able to run 8.90's in the heat of summer, I'm thinking it will do better than that now.
 Post Posted: Thu Mar 25, 2010 5:08 pm
You guys are funny but mine went 8.70s in the heat of the summer in 90+ humidity ;-)
 Post Posted: Thu Mar 25, 2010 5:31 pm
935hp @ 7200 ... 8.80's =;
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
http://www.diamondracecars.com
Fleenor Racing Glides
"get one before one gets you"
 Post Posted: Fri Jun 25, 2010 9:04 pm
Hammertime, I'd be real happy with 935 hp, but I am hoping to run the local 8.50 Index without nitrous. I finally got some more numbers, the intake ports ended up being 355 cc and the compression ratio is 15.25
 Post Posted: Sun Oct 10, 2010 10:04 pm
Changed cars, this engine is now going in a 69 Nova round tube chassis, 4 link, same gear, trans and tire, should weigh 2650 with me in it.
 Post Posted: Mon Oct 11, 2010 5:11 am
Donee, I would save some $$$ and get it dynoed..It is worth the $$$ for sure..
If it don't make almost 1 thousand hp I think I would not be happy as my cam is smaller,heads are smaller and your compression is over 1 point higher...
If you want and the snow is flying here I will be happy to send you my carb to run on the dyno or the track ;-) ...
Sorry I missed your call last night but was driving (trying) out of the city as I took my better half to see a play...
 Post Posted: Mon Oct 11, 2010 4:11 pm
Thanks for the offer Barry, I think I'll be trying a Large Carby from Shrinker. But I will probably baseline it with my 1050. Nice to know yours liked a larger Carb.
As for the Dyno, I just spent my Dyno money upgrading my Data logger. So I'll be logging 8 EGTs and 8 O2s, plus a bunch of other channels.
I'll call you later.
 Post Posted: Sat Oct 23, 2010 6:32 am
I think your right Barry, and it be interesting to see what the car does with both carbs tried. :-k
My guess is, it will make over 1000hp and about 794ftlbs of torque around 7700 rpm's
 Post Posted: Sat Oct 23, 2010 6:41 am
A PLAY! O:) I bet you wear slipper's, PJ's and a bathrobe too =; =;
I know I know, gotta take care of our honey's right? ;-) =;
I went to see the play (WICKED) which is a story about the wicked whitch of the East and what an awesome play \:D/
Users browsing this forum: Bing [Bot] and 10 guests
