fired the 498 finally
Author:  gnicholson [ Sat Jul 17, 2010 9:11 pm ]
Post subject:  fired the 498 finally
i started the 498 today for the 1st time. its a 13.5 motor with320 cc heads, 279 286 748cam on 110, drj ported edelbrock intake with a 1050 4500. sounds good. has 45 lbs hot at idle in gear with std ls6 pump. no leaks. i had to add a little idle speed and a bit more idle mixture than the 12 to 1 468 but its new. good so far . the old 468 ran a best of 9.69 , hopefully this is 3 or 4 tenths faster
Author:  Slowpoke [ Sat Jul 17, 2010 10:22 pm ]
Post subject:  Re: fired the 498 finally
Good Deal!!! Keep us posted.
Author:  traysvega [ Sun Jul 18, 2010 10:37 am ]
Good Job,Cant wait to see how she does. \:D/
Author:  gnicholson [ Mon Jul 19, 2010 11:00 pm ]
thanks guys. im kind of interested to get it out and see what happens. i need to get the throotle stop ratio figured out before the next nhra race
Author:  BarryW [ Tue Jul 20, 2010 1:41 pm ]
It oughta be a hoss! Let us know what she does!
Author:  gnicholson [ Tue Jul 20, 2010 2:20 pm ]
its going in a 70 chevelle. a very nice car but back halved with stock front suspension. the front pushes a lot of air. it will have about 100 more hp than the 468 or 800 but im guessing 3 tenths faster max and 140 mph over the previous 468 that typically ran 133.what do you guys think?
Author:  rick360 [ Tue Jul 20, 2010 5:18 pm ]
.3 et and +7 mph sounds about right if it gains 100hp over the 468. Keep us posted on the results.
Are the 320 heads ported? Flow #'s? Valve sizes?
Author:  gnicholson [ Wed Jul 21, 2010 9:52 pm ]
the heads are 1990 vintage brodix castings originally ported by afr in the same year. we redid the valve job and used angles recommended by mondellos porting supply and a radius cutter for the exhaust. the heads flowed a little over 370 and 300 @700. the port work and valve job picked up about 30 cfm on the intake and somewhat less onthe exhaust at mid lift. i need to get the figures out.the intake was ported by dr j. 279 286 on 110 with 749 lift. a little over 13 to 1. comp belt drive,je pistons, callies crank and rods, 1050, 2 i/8 headers with a merge collector going from 3 1/4 to 4 inches
Author:  gnicholson [ Sat Jul 31, 2010 9:28 pm ]
i finally ran at the track today. unfortunately it was all 1/8 mile. i wanted to run the 1/4 to get some tuning done and get the throttle stop figured out for the next divisional race. i left the stop on. it ran 2-3 hundreths quicker every pass. the lat was a 7.098 with 2 seconds of timer. should run 6 0's wot in the same conditions which were low 90's 29.95 and 75% humidity. the data logging quit on my fast meter so i need to get that fixed. should be ready to tune next time
