 Post subject: Oil level
 Post Posted: Sat Jul 10, 2010 4:01 pm
I have BBC with a Moroso pan. The pan is rated at 6 qts + the filter. I use the short Wix racing filter that holds about 1/2 qt. The engine has oil restrictors to the topend and a Mellings HV pump. The math says 6 1/2 qts. Would I be safe running less oil to move the level away from the crank to reduce windage?
84 Regal
3300 lbs
482" BBC
1.35 60'
6.30/107.5
9.98/132.5
 Post subject: Re: Oil level
 Post Posted: Thu Jul 15, 2010 3:12 pm
Dont run it low with a HV pump. That pump can suck the pan dry. (maybe not with restrictors though) Just because your dipstick said its full or overfull doesnt mean its at that level going down track. I bet there is only a few litres in there at higher rpm. The oil is probably not even close to the crank. A windage tray would be mutch better than running it low on oil. I would also remove the restrictors to get more oil to the springs, rockers and lifters.
 Post Posted: Thu Jul 15, 2010 4:18 pm
I've heard running low oil level has been an old Stock or Super Stock trick for picking up a hundredth or two when desperate. It might gain a very small bit of ET or MPH, but for bracket racing it certainly seems like a big risk for a very small reward.
 Post Posted: Thu Jul 15, 2010 11:22 pm
I have to agree with rick. High risk low reward.
