 Post subject: cold welding blocks
 Post Posted: Sat Jan 30, 2010 10:16 pm
Hi Guys
When you guys grind out the bottom of the block for crank and rod clearance and cut into the water jacket, what rods, or how do you weld them up. Its not a structural type weld, just a small bead to fill in the hole.
VK Commodore
383 Holden
2 speed Glide
Everthing on this car is all done by myself
650 HP Plus 300 Nos
Best so far
1.38 60 ft, 6.3 1/8 at 110 mph and 10.2 at 135 mph, long way to go before i reach my low nine hey
 Post subject: Re: cold welding blocks
 Post Posted: Tue Feb 16, 2010 12:26 am
If its just a small hole I would use epoxy over the hole after I grouted the bottom half of the block.
If you insist on welding try a silicon bronze rod with a TIG torch or a high nickle rod.
BTW, what is your definition of a cold weld??
Bruce Lee
http://www.mhpmachine.com
