 Post subject: Deck Clearance
 Post Posted: Fri Jan 08, 2010 8:33 pm
Hi Guys
When you guys set up your piston to deck clearance, do you always shoot for zero. Was wondering if any of you drop the pistons down say 10 or 15 thou so you could maybe deck the block again if ever required.
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
 Post subject: Re: Deck Clearance
 Post Posted: Fri Jan 08, 2010 10:08 pm
MINE ARE .003 OUT OF THE HOLE WITH AN .040 GASKET! She's been 8600 with zero problems! In fact, I ran that same block at 003 out on a 23* engine for about near 9 years.
 Post Posted: Sat Jan 09, 2010 11:06 am
Ours is about the same with 23* heads milled.070. Ours was 0 but when they redid the mains they pushed out a little. I know a couple of guys run them out more.
 Post Posted: Sat Jan 09, 2010 1:41 pm
Mine are even with the deck with a .042 gasket. I run titanium rods. I think I used to run an extra .030 when I ran aluminum rods. Of course I think it's a matter if you want to maximize the performance with the highest possible compression ratio or stay a little conservative and try to leave room for damage repair.
 Post Posted: Sat Jan 09, 2010 5:50 pm
Gearhead
Ye thats exactly what I was getting at, but I dont want to sacrifce HP. Was thinking of leaving them 15 below the deck but that just means taking more of the heads. Well that isnt much use then anyway as you leave little damage safety in the heads. Suppose I could always start with the thinnest head gasket and have some safety margin in the block and head, then if need be, can machine some of those surfaces and then just increase the head gasket thickness.
Thanks guys
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
 Post Posted: Sat Jan 09, 2010 5:59 pm
If a customer brings in a block to get decked i leave them .005 in the hole unless they say different. As piston to wall increases the piston will rock over and take up most of the deck clearance.
Mike
 Post Posted: Sat Jan 09, 2010 6:55 pm
Good advice Mike, my old 496 was .004 out and loose. It would make contact with the head. Never gave any trouble, just removed a little out of the chambers and good to go.
