 Post subject: Balancing
 Post Posted: Tue Jan 05, 2010 12:58 am
Hey guys
Engine was balanced with piston and pin package that weighed 584 grams, new piston and pin package weighs 590 grams. Who would run the new pistons without re balancing and who would re balance.
Trev
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
 Post subject: Re: Balancing
 Post Posted: Tue Jan 05, 2010 1:01 am
I would! They normally don't get any closer than 4 grams to begin with.
 Post Posted: Tue Jan 05, 2010 9:57 am
I'd run it like it is. I've been told that a few grams don't make any difference. I guess it depends on how hard you spin it, maybe if you were getting into that 10k rpm range you would have to worry...
 Post Posted: Tue Jan 05, 2010 10:20 am
If the engine was balanced with an over balance, (typical around here) odds are you still have a little over balance.
Lets say the bobweight used to balance your crank was 1750 grams.(a guess) Since just one pistons weight is used to come up with the bobweight on a 90* v8, you would change the bobweight 6 grams. 6/1750=.0034285% change in the bobweight. The typical over balance is 1-2%. 1% of 1750= 17.5 grams.
Randy
