 Post subject: engine build
 Post Posted: Mon Apr 24, 2006 10:27 am
so here is my plan for the lower end gioing with 350 sbc block bored .30 over torque plated, eagle 4340 crank, eagle 4340 3.480 throw, 5.700 h- beam rods clevite 77 bearings thats my start i am looking at 500+ hp wiht the blower hopefully but im not sure about the cam any sugestions i want a mean idle
im planning on dart iron eagle heads with 230 cc and angles plugs weiand blower wiht weiand intake manifold, holley supercharger carbs, msd 6al ignition flat top pro billet distributor, and a blaster coil any more sugestions
i know i left some stuf out but lety me know ill answer your ? oh this is going in a 73 nova custom soon to have subframe conectors front power disc brakes and more its going to be a sleep for about a month or so when i get this all taken care of b/c oviuosly im going to be short on $ for a nice paint job
 Post Posted: Mon Apr 24, 2006 4:30 pm
Power disc brakes and a big rumpty rump cam DO NOT play well together! O:) Depending on how much duration you decide to go with, some mild cams may be OK with the addition of a vacuum storage canister mounted somewhere in the engine bay.
In the late 60s, when the first Z28 Camaros with off road cams came out they were NOT offered with power brakes for this reason. They did have a manual disk brake available but not one with power assist. Something to think about!
 Post Posted: Mon Apr 24, 2006 7:11 pm
so i guess your saying i have to go wiht a mild cam then i was already plannig on a canister
 Post Posted: Mon Apr 24, 2006 7:42 pm
What will your compression be.
Mike
 Post Posted: Mon Apr 24, 2006 10:55 pm
speaking of brakes, i dont even have a brake booster on my truck....although they all came with one, any idea why mine would have been taken off? Heres a pic
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
 Post Posted: Tue Apr 25, 2006 6:42 am
your truck has factory Manual brakes..No Booster.
And about the power brakes I use a Vacuum canister and a good sized cam and my brakes work fine..at least at the track. But as some have already said you do not need a huge cam with a blower.
 Post Posted: Tue Apr 25, 2006 7:31 am
what info do you need i was planning on like a 2500 stall convertor on a 400 and something like 3:73 gears im planing on runnning this vechicle at the track and on the street
