Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post Posted: Fri Apr 21, 2006 8:29 pm
You know i might be wrong on the crane i don,t see them in there new catalog but i know crower dose. The crane i used were new but i had to get them from Motor State.
ps. found them
Mike
http://www.rogersperformance.com/
 Post Posted: Wed May 03, 2006 5:40 pm
well i looked the number up on them and they are for a big block..but thanks
 Post subject: CMON AUSSIES CMON
 Post Posted: Thu May 04, 2006 4:27 am
CMON AUSSIES CMON
Hey guys, I wanna blow the trumpet for a good old aussie company that makes roller rockers.
They arent toys or pretty looking things with flash colours but they certainly are quality that i think may even be better than Crane and Crower. Yes i know its a big statment but a couple of years ago Yella Terra went to the states and attended some big performance parts show thing and won an award for their roller rockers.
Oh why am I posting, they make rockers for CHEV S/B and B/B in all those ratios you are talking about. Shaft types and pedastal types etc.
If anyone is interested i can track down the american distributor for them.
Trev
VK Commodore
383 Holden
2 speed Glide
650 HP Plus 300 Nos
Best so far
 Post Posted: Thu May 04, 2006 7:20 pm
why is shaft rockers so much better?
 Post Posted: Thu May 04, 2006 7:42 pm
The shaft rockers are more stable the shaft interconnects all the rockers and uses their previous mounting points as triagulation on a bridge. you spread the load to each stud, so your not going to move, pull or break a stud, because it now has help from others.
 Post Posted: Thu May 04, 2006 7:57 pm
I do know ,,they dont require no where near the adjustment of standard rockers With a stud girldle...Been there done that...And like my shaft setup.... =;
 Post Posted: Fri May 05, 2006 3:29 pm
heres the rockers i got that i was wondering if they would work on a small block chevy but looked up numbers they are for big chevy
http://i83.photobucket.com/albums/j289/ProBlaze/rockers.jpg
 Post Posted: Mon May 08, 2006 3:08 pm
Avery wrote:
if they will work im going to put them on a 400 sbc and run it on sreet and strip
Avery....stay away from these...use 1.5 or 1.6 specifically for the SBC heads you are using....using the 1.7's require extensive machining to get them to work...Duane, Rick, Mike, Curtis, Mel....but that is why you asked the question so you dont piss away good money.....you can buy good roller rockers for not a whole lot of money...Harland Sharp, Proform, even GM Performance parts has good ones that last and are cheaper.... \:D/ \:D/
James
79 Z28 496 BBC....
 Post Posted: Mon May 08, 2006 3:13 pm
thanks i found out that they were for a big block so im not using them
 Post Posted: Fri May 12, 2006 6:54 pm
here's my experiances,
ok i have run cranes and harland shraps in the past on my bbc motors. i have had absolutly no problems outta either brand.(knock on wood).
i know a guy who was running a set of lunati and had less than 30 runs on them and were junk(bbc). but he has issues w/cam walk so what's the real problem? cam walk!
i also know a guy who has a 572 in a dragster that runs 7.50's. he runs jesel shaft mounts. he broke two of them and replaced them during the course of the year. at the end of the year 10 outta 16 more were cracked!!!! called jesel and they said buy a new set. these were less than 2 yrs old on the whole set. now this motor was assembled by a reputable engine shop in my area. they were on a set of pro top line heads.
i'm not saying that there is a problem w/lunati or jesel parts just what i know of from these guys. like i said i run harland sharps and cranes and have no issues. but i also use a girdle.
why spend the money on shaft mounted rockers when you don't hafta? put the xtra money in something that's harder to change (rods,pistons, etc). i say put some sharps on it w/a stud girdle and you will be fine!!!
corey
