 Post Posted: Sun Jun 03, 2012 11:26 pm
Just about ready to take the roadster out for TNT (planning Wednesday).
Same roadster I ran a few years ago with a different engine. Details below.
Let's hear your guesses about what it will run. (1/8 mile guesses)
Car-
Weight - ~2000lbs
Gear- 4.56
Trans - Powerglide; 1.82 low and trans-brake
Converter - A1 8" race converter; stalls 4800 with this engine.
Tires - 16 - 33 -15 Hoosier slicks
Engine-
355ci - very mild street engine
Heads - Vortec 062 (Production) castings with very mild cleanup. Flow 240cfm max @ .450" lift, less at higher lifts.
Intake - Edelbrock Performer for Vortec. - stock, NO port work, NO spacer
Carb - Holley 750DP, no mods
Pistons - Dished 8.5:1 compression, stock rings
Headers - 2" primaries into Flowmaster collector mufflers
Cam - 234º/234º @ .050", .480"/.480" lift, 112º LSA hydraulic flat tappet.
Fuel - 87octane pump gas (same as truck and mower)
 Post Posted: Sun Jun 03, 2012 11:35 pm
ET 6.36 in the 1/8th. Is that weight with a fat arse driver or not.
 Post Posted: Mon Jun 04, 2012 12:00 am
Yes, with driver, but not that fat.
 Post Posted: Mon Jun 04, 2012 12:21 am
I'll stick with that time then. =;
 Post Posted: Sat Jul 07, 2012 6:08 pm
OK Rick, how about it? Have you made it to the track with this car yet? :-k
 Post Posted: Sat Jul 07, 2012 10:19 pm
Didn't bother posting results due to lack of interest.
After a trans problem the first time out and putting the dragster trans & converter in it ran a 6.77 @ 98. Air was ~3000DA
Oh, and I weighed it ... 1930#. It's not a killer but looks like it might be consistent.
Gotta get cooler here for me to take it racing. :-({|=
PS: Shrinker was the only one who guessed and he didn't win cause he was so far off. =;
 Post Posted: Sat Jul 07, 2012 11:16 pm
I guess that's respectable enough, and cheap to run as well. Now you watch, that thing will probably win you more races than anything else you've ever owned. So much so that I'll bet you think twice about selling it!! ;-)
 Post Posted: Sun Jul 08, 2012 7:28 am
Run some E85 in it and it should crack a hundred =;
 Post Posted: Sun Jul 08, 2012 7:59 am
Rick, There is more interest here than you realize. I didnt guess because I suck at making those predictions. I do however enjoy reading about how you did and will enjoy any progress updates and upgrades.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Sun Jul 08, 2012 8:12 am
X2.... I'm always interested in what you post, some of us aren't as outgoing as others.
 Post Posted: Sun Jul 08, 2012 8:36 am
Yeah, I didn't make a guess either cuz I didn't have a clue. The engine specs said POS stocker but I knew that car was going to be light. Just couldn't come up with a number is all.
Next thing I want to see is a PM with a write up for that win! ;-) With no more engine than that, I'll bet that thing will hook in a mud hole! =;
 Post Posted: Sun Jul 08, 2012 8:43 am
Yes on the ET guessing also as I really $uck on the guessing on "Pass time" show..But do like watching to see some of the iron some other run.. =;
