 Post subject: 78 camaro woes
 Post Posted: Sat Apr 21, 2012 6:24 am
been a tough year so far with our car. gonna have to miss an event today, as i can not for the life of me figure out what is going on with car.
we went tnt last night for todays event. made 4 passes but to avail, has been acting the same for the past three weeks.
car is struggling to get down track, starts breaking up around the 330 mark.
most of the issues have been ignition related. the "burnout" side of my launch control is engaging down track. confirmed that last night trying 3 different chips.
recently replaced the pickup on the crank trigger about a month ago. so last night decided to bypass crank trigger and trigger from dizzy.
this time the car made it to 660 marker, then started to break up. when i mean break, it is every so slighty, just enough for me to abort run.
i have checked all the obvious things, plugs, tested wires, cap, rotor, timing, valve lash. compression.
gonna to see if i can run down another ignition box and dizzy today, as we have a race tomorrow i would like to race.
if have anybody can look into their magic ball, and spread some wisdom.
 Post subject: Re: 78 camaro woes
 Post Posted: Sat Apr 21, 2012 7:03 am
What box?? Are you sure it's not gas related????
What's your fuel pressure going down track??
 Post Posted: Sat Apr 21, 2012 8:08 am
Have you checked your valve springs? Easy to check and rule out, and 1 broken valve spring will act like that. Ask me how I know! =;
 Post Posted: Sat Apr 21, 2012 9:22 am
using a msd 6al. gone thru entire fuel system from tank all way to carb.
a few weeks ago i thought was a fuel issue, tried increasing fuel pressure, jetted carb, adjusted float levels.
ended up being my crank trigger pick up(this time). was able to make three flawless passes when we used pick up on dizzy.
fuel pressure down track is at 7psi, stable entire run
fixing to pull valve covers off and check springs.
 Post Posted: Sat Apr 21, 2012 10:07 am
I know that every time I hear these symptoms I start crying proper grounding,...but it does happen. Something else I've seen is the pick up wires to the box being wired in backwards. Easiest way to tell is while I'm stabbing the distributor for the first time.
Bring #1 cylinder up to TDC on the firing stroke. Point the rotor to the #1 tower on your distributor. (I usually point it to just before it.) Will usually be around 30°-35°,...if you have to turn the distributor about 90° to get it to fire then the pick up wires are probably reversed.
But make sure your battery ground goes to your block.
 Post Posted: Sat Apr 21, 2012 10:15 am
X2 Although I heard about it before I had to learn the hard way. Here's a link to thread from my troubles.
viewtopic.php?f=7&t=8316&start=0
 Post Posted: Sat Apr 21, 2012 10:19 am
no broke springs, but valve stem tip on number 8 exhaust has a very noticeable wear pattern from roller rocker. can not check spring checker, as i do not have tool
yes, i read somewhere in the past on msd site that if the pickup wires were backwards it would create an advance on timing
i am pretty confident, i have it wire corrected, but i will check none the less
have a #2 wire from one head to other head then back to battery. have a #8 ground wire from battery to a terminal stud in cockpit, all electronics are grounded to this stud.
 Post Posted: Sat Apr 21, 2012 3:54 pm
borrowed a 6al and another dizzy, going to try the 6al first this coming wednesday night
 Post Posted: Sun Apr 22, 2012 2:17 am
Paint under the ground terminal on the heads?....Sorry, had to ask.
 Post Posted: Sun Apr 22, 2012 7:17 am
no paint, i always sand/scuff metal. good point
off msd website
"If you’re not sure about the polarity of the pickup you are using, there is a simple test you can perform by checking the engine’s timing. Check the timing with the pickup wires connected one way, then swap the wires and check the timing again. You will notice that the timing changes significantly and may appear very erratic. The correct connection depends on the ignition control that is being used.Analog: If you are using an analog controlled MSD Ignition such as a 6A, 6T or 6AL series, SCI series, 7AL series, MSD 8 or 10 or Blaster Ignition, the correct connection is when the timing is retarded.Digital: When using an MSD Digital-6 or Digital-7 Plus, or the Programmable Digital-7 Ignition Controls, the correct connection is when the timing is more advanced."
so i decided to check both pickups , dizzy then crank trigger.
dizzy
green-purple
purple-orange
timing 39 degrees, vary stable
reversed wires
purple-purple
green-orange
timing 50 degrees, vary eradicate
crank trigger
green-green
purple-purple
reversed wires
purple-green
green-purple
timing 34 degrees, vary stable
it appears my crank trigger was wired backwards.
probably reason why i have had problems with my last two pickups.
of course i am using a 6al(analog) system.
food for thought.
 Post Posted: Sun Apr 22, 2012 9:26 am
themadreefer wrote:
off msd website
Now that's good info as I was under the impression that they were all wired the same?? :-k Thanks
 Post Posted: Sun Apr 22, 2012 4:21 pm
Thats why we use points. [-(
 Post Posted: Sun Apr 22, 2012 7:03 pm
not that i am old or something, boy i sure miss them things, along with the dwell meter 8-[ 8-[
 Post Posted: Sun Apr 22, 2012 7:39 pm
Yeah stuff was simple back then. You just cleaned the carby in a bucket and off you went again. try doing that with EFI.
 Post Posted: Thu Apr 26, 2012 5:15 am
went racing last night, and boy was it a good night.
the only change i made between races, was reverse the leads on crank trigger pick up.
car ran fricking great last night \:D/ \:D/ \:D/
actually set my new low et being 9.8 at 136
was cutting good lights all night long, except for first round eliminations, in which i decided to take a nap on line.
well anyway all appears good. cant wait till next wednesday.
thanks
