 Post Posted: Fri Mar 02, 2012 6:33 am
right now I have a turbo 350 trans 4.56 gear I run in the 1/4,I foot brake the car no power adders.I was thinking of running 1/8 mile,what size gear should I switch to if I decide to run 1/8 mile?car weighs 3064 lbs with me in it.
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Fri Mar 02, 2012 2:19 pm
We run 4.56 and 29.5x9x15. On a great weather day the shift light (6500) around 6.80. comes on at the 1/8th finish line. We run the same set up on the 1/4 and it hits about 7200 10.74 is our best.
 Post Posted: Fri Mar 02, 2012 2:33 pm
Studebaker is 3500 lbs wet. It's got a pump gas 434 SBC in it, a Glide with a 1:96 low, 33" tires and a 5:13 rear gear.
Quarter mile speeds were around 134 @ 7700 RPM and eight mile were 106 @ around 7K RPM. That car was under geared for the eight mile and over geared for the quarter, ie, should have had a 5:38 for eight mile and a 4:88 for quarter mile.
 Post Posted: Fri Mar 02, 2012 8:36 pm
You want to be careful on how much gear you add with the turbo 350, It will hit the tire harder and make the launch more violent and possibly make it inconsistent. I would be willing to bet there would be minimal gains going any deeper with the gears.
How fast is the car?
74 Nova
 Post Posted: Fri Mar 02, 2012 8:46 pm
Ken I think he would run out of RPM with those gears. unless he runs a 33' tire. I don't know what motor, shift points or tire size though.
 Post Posted: Fri Mar 02, 2012 11:01 pm
Yeah Steve that 5:13 can be a little deep for some. That's why I mentioned the 33" tires on the Studebaker as he didn't say what tire he has on that car.
On the highway I have to run 3500 RPM to run with traffic @ 55/58 MPH. =; On the expressway everyone is passing me except when I do those "short bursts"! ;-) \:D/
 Post Posted: Sat Mar 03, 2012 5:11 am
Car runs 10.00-9.99 and i shift at 7200, thru the trap at 74-7500.
406 cid
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Sat Mar 03, 2012 6:31 am
I do think I'd run the eight mile it a time or two to see where you are with the 4:56. I'm guessing that it's going to be around 6600/6800.
Is this a Phord rear?
What is the MPH @ the stripe?
 Post Posted: Sat Mar 03, 2012 9:26 am
8.5 10 bolt moser spool axles and gear,28x9x15 tire,132 mph at the end of 1/4
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Sat Mar 03, 2012 5:38 pm
Jeff here's a link to some automotive calculators that may help you in your search for the proper gear.
viewtopic.php?f=4&t=7859
My guess is that you'll probably need at least 5:13 in that car but I wouldn't do anything until I ran it eight mile and checked where you are RPM wise.
 Post Posted: Sat Mar 03, 2012 8:04 pm
My 55 is around 3200 lb and i run a 5.14 with 33 tires. When it was blown i ran a 6.00 gear in it.
 Post Posted: Sat Mar 03, 2012 10:07 pm
When I was blown I didn't run anywhere!! O:) Knees too weak! =; \:D/
 Post Posted: Sun Mar 04, 2012 7:35 pm
You got that right Ken =D>
