 Post subject: roll cage
 Post Posted: Thu Feb 02, 2012 10:48 am
Am I aloud to drill a hole or screw a part to my roll cage.
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post subject: Re: roll cage
 Post Posted: Thu Feb 02, 2012 12:27 pm
Where???
 Post Posted: Thu Feb 02, 2012 12:57 pm
bars in engine compartment
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Thu Feb 02, 2012 3:54 pm
I think you can do whatever you want to bars in the engine compartment. The chassis cert is for the cage area, but I know I've seen cars with mounting holes in bars in the cage also.
 Post Posted: Thu Feb 02, 2012 5:28 pm
Jeff I drilled 1/8 holes in mine to attach wire to and also the overhead switch box and my logger to. Also same holes for the brake lines...Here a couple pictures...
 Post Posted: Thu Feb 02, 2012 5:48 pm
I use zip ties on the dragster chassis but the brake lines (rear only) are run inside the frame tube. And if it needs to be fasten REALLY good, I use SS hose clamps as THAT is all that's holding the front of the ENGINE in the chassis! O:) \:D/
 Post Posted: Fri Feb 03, 2012 1:38 am
Ditto here. for bigger stuff you usually will want to weld in a threaded insert.
Heck, on the closed tube ends where welding is done, my chassis (Willie Rells) drilled 1/8" holes for the welding gas to escape.
