 Post Posted: Mon Dec 19, 2011 9:37 pm
ECBRC has started two new classes for 2012..
1.6 litre and 2.5 litre hydro classes..
Team Extreme has decided to get onboard with the new classes..
Team Extreme has purchased a 2.5 litre hydro running the ford 2300 pinto engine.Did i just say that??? HAHAHAHA.. Even though it is a 4cyl craft it is 100MPH + hull.
The 2300 ford pinto motor is no stranger to me i use to build pro four engines at the speed shop..Can you say 9800 rpm HAHAHA..ZING...
Only bad part> engine must remain stock, stock cam,lifters and springs, stock rods can use srp pistons part# 148221 and 148222.
can use adjustable cam gear. Dist and flywheel are only 2 other parts that can deviate from stock and must run an aluminum flywheel with 135 tooth gear or 132 for 2300 pinto engine..
 Post Posted: Mon Dec 19, 2011 9:44 pm
Sounds interesting. When are you going to step up to Turbines? \:D/ \:D/
 Post Posted: Mon Dec 19, 2011 10:01 pm
Is there a carby or induction rule?
 Post Posted: Tue Dec 20, 2011 5:40 am
Had a friend that had a friend :- that raced one in a road race car and he could not get it to stop shaking
the needles off the gauges... \:D/
 Post Posted: Tue Dec 20, 2011 8:49 am
Love the hydros. Gotta be tough on a runabout guy. My involvement with APBA was stricktly outboard hydros. That 2300 class will be exciting. Keep us informed.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Tue Dec 20, 2011 9:00 am
yes their is a carb rule you can run both rochester 2bbl and holley 2300 series..
bore,venturi and throtthle plate diameters are checked according to their spec..
Should be intresting Thanks guy's..
