Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post Posted: Thu Apr 20, 2006 9:00 pm
My Launch rpm is 4000 to 4400 what do you think of that?
 Post Posted: Thu Apr 20, 2006 9:12 pm
Are you 2-stepping it down on the line? What does the converter stall. Seems the 1/8mile speed is fast for the ET, what is your 60'. Are you spinning?
Normally 6.0's will get you 112-114.
 Post Posted: Thu Apr 20, 2006 9:14 pm
Have not test stall this year with new power. two step at 4000 last year it stalled at 5900 1.304 60ft
 Post Posted: Thu Apr 20, 2006 9:16 pm
Yes the mph at that track is about 2 faster then any other I go to.
 Post Posted: Thu Apr 20, 2006 9:21 pm
The 60' looks good. The converter probably stalls more with the added power. May slip more than the 5% I was figuring. Converter seems borderline too loose.
 Post Posted: Thu Apr 20, 2006 9:25 pm
Also the car weighted 200 pounds more last year. What should the converter stall at?
 Post Posted: Thu Apr 20, 2006 9:28 pm
Rick take a look at the link. Tire does make a quarter turn before the car moves. you can only see it in slow motion.
http://videos.streetfire.net/video/9E5C ... B76D0D.htm
 Post Posted: Thu Apr 20, 2006 9:41 pm
It's hard to say where the stall should be without knowing everything about the engine, but most importantly a dyno sheet. To run quickest it is usually best to have the stall about 500rpm past peak tq, but that depends some on the tq/hp curve and how fast it falls off after peak hp. An overall range of 1200-1500 rpm from stall speed to shift point should be close.
