 Post Posted: Thu Sep 29, 2011 8:44 pm
VENT TUBE FIRE RESTRICTORS
The problem…Fire
Fire, the most feared occurrence for a race car driver. What can we do to minimize this threat? We currently mandate protective clothing, we mandate on-board fire extinguishing systems, what else can we do?
We can address the likely places where fuel can come into contact with hot engine components, such as exhaust headers. In this context, the most logical area to address is the vent tubes on carburetors.
Whenever a race car impacts the retaining wall, turns over in a roll-over crash, turns over on its side, even slams down to earth after a violent wheel stand, raw fuel can surge or splash out of the carburetor vent tubes. The average carburetor float bowl contains approximately 80 to 100 cc’s of gasoline, depending on the float settings, and each 4-barrel carburetor has two float bowls. 160 to 200 cc’s of gasoline (almost 7 ounces of gasoline) on hot engine parts is more than enough to ignite a serious fire, and you can double the fuel volume on dual carb engines. Even shutting off an electric fuel pump with the battery cutoff switch will not stop the fuel from coming out of the vent tubes in many situations. And once the fire starts….
The solution… Vent Tube Fire Restrictors
Accufab's billet aluminum Vent Tube Fire Restrictors, a simple and inexpensive ball-check valve, installed on each vent tube will minimize or restrict any raw fuel surge through the vent tubes without restricting the vent tube’s ability to VENT, and takes less than a minute to install. Engine dyno tests conducted at Westech Performance Group in Mira Loma, CA, have demonstrated that Vent Tube Fire Restrictors mounted on race carburetors, in both single and dual carb applications, in back-to-back testing, showed no loss of horsepower or engine performance. Several different Holley, Barry Grant and similar aftermarket carburetor variations were tested. None showed any power losses after the installation of the Vent Tube Fire Restrictors, zero.
Vent Tube Fire Restrictors, available now from Accufab, Inc., (909) 930-1751.
http://i734.photobucket.com/albums/ww342/WR169/0014.jpg
Open vent tubes...
http://i734.photobucket.com/albums/ww342/WR169/0023.jpg
Accufab's billet aluminum Vent Tube Fire Restrictors installed.
__________________
 Post Posted: Fri Sep 30, 2011 5:11 am
Hey thanks for sharing that info Steve!!! =;
 Post Posted: Fri Sep 30, 2011 8:37 am
I thought it was pretty cool.
 Post Posted: Fri Sep 30, 2011 11:00 am
That would make it a little hard to use a flute. I can see where there would be no difference on a dyno but there could be a difference on the track. Of course it would be easy enough to A/B test.
 Post Posted: Fri Sep 30, 2011 7:12 pm
I wonder if the fuel coming up would push the ball up and block the fuel from coming out.
