 Post Posted: Sun Jun 14, 2009 12:38 pm
hello fellas, i'm tired of the fighting the accel system and am going back to carb, so these questions pertain to the changeover and a couple other question possibilities:
presently is sbf 351/406ci 9.8 comp accel efi with sup vic intake, solid roller cam 244/244 .600 110lsa, afr205 heads unmodified
will have to change the intake, prob vic jr or rpm air gap, considering changing to milder hyd roller cam, and of course a carb.
can the efi fuel pump be used with the carb with return line, it is a walbro and don't know if the flow will have any adverse affects.
afr heads have 225# seat pressure is this compatible with hyd roller also?
the cam is billet, and doesn't drive the oil pump, can i use a cast dist. gear that comes with the dist. i order, and what dist. would be the best, using 6al now with blaster coil. thinking i want a dist. with large cap and if i do this might require rpm air gap manifold.
can this cam be used with an rpm air gap?
idle vacuum is 7-8", will this pose a problem with carb? cruise vacuum is 6-7".
what would be a good hyd roller cam using 1.7-1 rockers?
 Post Posted: Fri Jul 10, 2009 8:56 pm
ok, i will take a stab at this.
1: no on the fuel pump pressure is way too high..
2:as per spring pressure you also need open press and go by cam card specs, if the card does not have the specs call the manufacturer for them.
3: as for the dist gear again contact the manufacturer.
4: msd, their are many to choose from.
5:yes you can use a carb with cam. just have too tune it. no problem with the idle vaccum just use the correct powervalve.
6: the cam co, could better answer cam application.
 Post Posted: Sat Jul 11, 2009 8:28 am
guess i should close this out. i am using a bg 750 rr carb on top of rpm air gap with davis hei distributor, runs good. kept the roller cam and everything below the manifold.
 Post Posted: Sun Jul 12, 2009 5:59 pm
You can use the EFI pump on a carby set up. You need the correct bypass style regulator and it will reduce the pressure to carby levels. A few manufacturers do them, Dont know where you buy them in USA though.
 Post Posted: Fri Jul 17, 2009 8:52 am
i just changed the regulator spring out for a softer one, usually when you buy one they come with two sets, luckily i had one sitting around, still had to cut one coil off.
