 Post subject: Rubber gaskets
 Post Posted: Tue Dec 11, 2012 3:53 am
I meant to post this question a while ago but of course other things had my attention, quicker ET! I noticed after a couple of months using E85 that my rubber felpro valve cover gaskets are basicly disintigrating. I had no issue using race gas and when I went to check valve lash the gaskets fell apart! My rubber oil pan end seals don't seam to have this issue. Has anyone else noticed this and if so, what material are you using?
Thanks, Keith
Keith
 Post subject: Re: Rubber gaskets
 Post Posted: Tue Dec 11, 2012 5:55 am
I am not having any issues here with them....Mine are the blue rubber with the steel inside..Guessing your using the same ones??
 Post Posted: Tue Dec 11, 2012 3:52 pm
Thanks Barry, No I'm using the plain black rubber felpro's. I was wondering if the blue ones like your using were that much different in material. I'll get a set along with the pan gasket just to be sure. Thanks.
Keith
 Post Posted: Tue Dec 11, 2012 4:26 pm
I'm running the blue felpro's on both valve covers and oil pan gaskets and haven't noticed any issues.
Mark Slayton
Rochester, NY
Quick Rod 130C
Super Comp 130C
