QFX/Holley Banjo's
http://motorsportsvillage.com/forum/viewtopic.php?f=21&t=9633
Author:  Beretta [ Wed Oct 10, 2012 4:51 pm ]
Post subject:  QFX/Holley Banjo's
I got this QFX main body from our Carb parts guy Bruce (nomad) and was looking at the difference in the skirt on the
banjo compared to the BLP that is on the HP carb now..
The bottom of the flair will be gone when I find someone that can remove it and make it .980 instead of what it is now..
QFX Banjo
BLP Banjo
Author:  Ken0069 [ Wed Oct 10, 2012 9:10 pm ]
Post subject:  Re: QFX/Holley Banjo's
If I had a rotary table for my mill I could machine those for ya. But I don't! Sorry. :-k
Author:  jmarkaudio [ Wed Oct 10, 2012 10:09 pm ]
I can. Bruce said you wanted another set, let me know if you want those cut and I'll take care of it. I have some expanding collets for a mill I use in my lathe, works like a charm.
Author:  jmarkaudio [ Wed Oct 10, 2012 10:12 pm ]
They look like this.
Author:  shrinker [ Thu Oct 11, 2012 12:00 am ]
Many years ago when I didnt have much in the way of machinery I made an adapter for the tool post on my lathe to fit a dye grinder into it. Then I put the booster into the lathe chuck, put the lathe in neutral and rotated the chuck with the key as a handle and brought the die grinder into the job. Pop one perfect booster job. You can put tapers on it, and do all sorts of things by angling the tool post; pretty cool huh. When there's a will there's a way.
Author:  Beretta [ Thu Oct 11, 2012 6:33 am ]
Thanks Mark. I will ask Bruce if he can get them to you when he gets them..
Thanks..........
Author:  mslayton [ Thu Oct 11, 2012 7:09 pm ]
Not trying to hijack the thread, but Does the Quickfuel main body accept Holley banjos? I actually have been meaning to contact nomad for a main body also, just been too tied up at work to think about it.
Author:  Beretta [ Thu Oct 11, 2012 7:56 pm ]
Not really Mark as you can see.. There also longer in length.. The Holley banjo's fit but real sloppy and the QF banjo's and less
money than the Holley/BLP banjo's and the BLP boosters fit the QF banjo's..
Author:  jmarkaudio [ Thu Oct 11, 2012 10:03 pm ]
The Holley banjo's will fit but as you can see the entrance taper is different. But the banjo's are not real expensive, and the booster inserts are interchangeable.
Author:  mslayton [ Fri Oct 12, 2012 8:40 am ]
Thanks - I was just wondering what needed to be on my shopping list.
Author:  Beretta [ Fri Oct 12, 2012 11:07 am ]
Your also going to need there throttle shaft kit....Bruce has them also..
Author:  mslayton [ Fri Oct 12, 2012 1:14 pm ]
Thanks Barry. Darn - I was hoping to use the BLP external linkage I already own. Oh well - I guess I can upgrade a different carb.
Author:  Beretta [ Fri Oct 12, 2012 2:08 pm ]
Maybe you can as I am not sure...Maybe Mark knows if you can..
Author:  jmarkaudio [ Fri Oct 12, 2012 2:11 pm ]
The external linkage from BLP is fine, you can't use Holley internal linkage.
