jet extentions
http://motorsportsvillage.com/forum/viewtopic.php?f=21&t=9293
Author:  Beretta [ Fri Jun 15, 2012 8:31 pm ]
Post subject:  jet extentions
What are you using for jet extensions for the 5/16 jets??
Author:  jmarkaudio [ Sat Jun 16, 2012 7:23 am ]
Post subject:  Re: jet extentions
If you are using the standard Holley style alcohol jets Quick fuel makes extensions for them.
Author:  Ken0069 [ Sat Jun 16, 2012 8:52 am ]
Yeah I've got the push on ones for the big jets but can't remember where I got them? I went looking last night but only found the screw in ones, which aren't the best IMHO.
Author:  Beretta [ Sat Jun 16, 2012 10:48 pm ]
Not going to do screw in jet extensions...I will just see if I can find some brass tubing that will fit I guess
Author:  Ken0069 [ Sat Jun 16, 2012 11:47 pm ]
I was thinking that too. Looks like 7/16 tubing would have a 3/8 ID.
Author:  nomad [ Mon Jun 18, 2012 8:21 am ]
I've seen some of the pushon extensions from Mr. Gasket and apparently BG. They're stainless and are flattened at the end so as not to require notched floats. They're for standard 1/4x28 jets only.
I'm wondering if these can be homemade for the 5/16 jets with a lathe to get the interior dimension correct. I'm also thinking that maybe these shouldn't be squashed on the end either. Just in case squashing reduces area smaller than that of an E85 jet orifice.
AED part number 5895
Percy's part number 15009
Moroso 65227
Author:  Beretta [ Thu Jun 21, 2012 8:32 pm ]
Well after searching high and low I only found a 3' piece of 3/8 od brass tubing so I though I would try to expand it to fit over the jet. It was only .014 wall and brass is soft and I did have 3' of it so didn't have much to loose except the 5 bucks I spent on it. Well it worked out really good on the first try. I expanded it on one end with a tapered punch and then found a 8mm Snap-on scocket was just a few thousand's smaller than 3/8 so I taped it into the brass tubing just a touch longer than the jet itself.
I then cut them to size and taped them on the jets. Worked out really nice and was cheep like Ken likes to do things :-# ......So my E85 carb is finished!!!!
So anyway if anybody need some jet extensions for alky jets let me know as I have plenty of material. \:D/
Hope to get some E85 next week and test on 30th as it's a open test and tune...
Author:  Ken0069 [ Thu Jun 21, 2012 11:21 pm ]
Glad you got that sorted out. Did they have any 7/16 OD stuff and if so, was it the same wall thickness? :-k
Author:  Beretta [ Fri Jun 22, 2012 4:41 am ]
Ken I could not find any 7/16 wall tubing anywhere at all..McMaster carr had some but expensive.
This like I said was a shot in the dark and it worked out good. Oh and the guy behind the counter said that he's not going to carry it anymore as it don't sell at all..
Author:  mslayton [ Fri Jun 22, 2012 4:24 pm ]
Good luck on the test next week, looks like you'll beat me out by at least a week since I'm still traveling for work every week. I just picked up an Innovate LM-2 to allow me to measure what's happening and would love to have it hooked up before I head out. This will me my first data acquisition experience, so it should make the first time out even more interesting. I'm sure I'll be picked everyone's Brian with questions soon also.
