ajcasini
Posted: Fri May 25, 2012 11:46 pm |
Well I picked up the first W of 2012 tonight. Car ran between 10.416-10.418 in 6 passes. Only round different was 1st went a 10.408.
Ken I need to look at logs tomorrow to see if pressure increase helped. Went to 6.5 psi.
mslayton
Posted: Sat May 26, 2012 1:00 pm |
Joined: Sun Jul 19, 2009 2:14 pm Posts: 83 Location: Rochester, NY
Awesome job AJ! Sounds like you've got the car dialed in so I'm sure this will be the first of many.
I finally fired my car on E85 for the first time today. I think I have a bad rear float so I'll needed to get that fixed and tune the idle a bit, but hopefully I'll finally be at, the track in 2-3 weeks. I'm looking forward to getting the dragster back on track for the first time in nearly 2 years.
_________________ Mark Slayton Rochester, NY Quick Rod 130C Super Comp 130C
Ken0069
Posted: Sat May 26, 2012 4:37 pm |
Site Admin |
Joined: Tue Apr 18, 2006 6:38 am Posts: 11633 Location: Coming At Ya!
mslayton wrote: I finally fired my car on E85 for the first time today. I think I have a bad rear float Or "O" rings or needle seat itself. If these N/Ss are SS then you might want to lap them if the float or "O" ring aren't the problem. FYI Barry was waiting on Mark for a tuneup for his 1250 so maybe you two can get your heads together with Bruce and do some "long distance" testing. Barry already has the parts he needs, he just needs the calibration to complete it.
mslayton
Posted: Sat May 26, 2012 7:27 pm |
Ken - your right, it might be the N&S because I changed the float and am still getting a much higher level than needed. It is a .150 stainless version, what process do I use to lap them?
Barry already reached out to me. I'll be sending him the info on my combo and the base set-up's I've gathered from info I've seem from others over the past 12-18 months.
Beretta
Posted: Sat May 26, 2012 7:30 pm |
Bruce sent me a set of 140 needle and seats.........Thinking maybe I will need 150's
Ken0069
Posted: Sat May 26, 2012 8:04 pm |
Site Admin |
Mark, I use an abrasive cleaner like Comet or Ajax with some WD-40 and lap them with that. Seems to work well and I believe that Eric68 started doing that also.  Barry, IMHO the .140s "should" be large enough.
mslayton
Posted: Sat May 26, 2012 9:06 pm |
Bruce, I think the .140's will be fine. I'm going to order some BLP viton .140's just to have them, but will clean mine up as Ken indicted.
ajcasini
Posted: Sat May 26, 2012 11:39 pm |
Yeah the 140s will be enough. That's what I ran in the 1250s I did last year for my engine builder. 9.0 hemi car and a 940 hemi car. Had enough fuel.
I also picked uP the W again tonight in modified. 2 for 2 with one to go tomorrow.
Feel free to give me a call to talk about any of the tuneups I have. You are welcome to the sheets.
Ken0069
Posted: Sun May 27, 2012 12:35 am |
Site Admin |
Are ya sure you can run viton with ethanol? Because you CAN'T run viton with methanol.
Ken0069
Posted: Sun May 27, 2012 12:37 am |
Site Admin |
ajcasini wrote: Yeah the 140s will be enough. That's what I ran in the 1250s I did last year for my engine builder. 9.0 hemi car and a 940 hemi car. Had enough fuel.
Feel free to give me a call to talk about any of the tuneups I have. You are welcome to the sheets. AJ you need to send me a writeup about these wins so I can have Faye put them up on our "Weekly Winners" page!! I've got two for Jody now that I've got to do Sunday (today).
mslayton
Posted: Sun May 27, 2012 4:55 am |
Ken - unless he changed them, I know Jmark was running .140 viton from BLP
Congrats again AJ, What an awesome weekend!
Beretta
Posted: Sun May 27, 2012 6:33 am |
Yep that what I have that Bruce sent to me was viton 140's. Fantastic job AJ!!!!!!!!!!! Congrats We may have to start a E85 winners circle
