 Post subject: Sunoco E85R
 Post Posted: Fri Feb 03, 2012 4:23 pm
Anyone here of anybody using it??? Im going to make some phone calls to see if it's available
somewhere around here...Looks like it comes out of philly so maybe worth the trip to get a drum..
Anyone have any commits??? Looks like there saying that it's never 85% it can vary a lot so I think that's going to mess with your tune up some....
http://www.racegas.com/fuel/18
 Post subject: Re: Sunoco E85R
 Post Posted: Fri Feb 03, 2012 4:58 pm
The whole reason to buy at the pump is to save money, and everything we test here has been 84% and above. Get your fuel in the summer for the year, and even if the % drops a little it won't be an issue if you have to get it another time of the year. Within 5% should be fine.
 Post Posted: Fri Feb 03, 2012 5:06 pm
I did get a tester so I will wait till april/may I guess..
 Post Posted: Sun Feb 05, 2012 9:41 am
Mark is right, this will be my fifth year on pump E85, works well and save about 70 % from what i use to spend on gas per outing. Beretta you tune and dial after a couple of TT passes, like any other fuel. The way i have e85 in the Spring is to buy it in early September for the next year, in the Buffalo area they switch to winter blend around the middle to end of Sept, and it stores very well in VP drum.
