 Post subject: Fuel supply for E-85
 Post Posted: Mon Nov 28, 2011 9:18 am
I have a Magna Fuel 300 pump and need to know if it will have enough...I have turned down the fuel pressure
to 15psi and have seen no difference at all from where it was set at the factory. That was 25psi..
Tank is front mounted and will hold 7psi steady for the run #10 feed to the pump and #8 to the regulator..
 Post subject: Re: Fuel supply for E-85
 Post Posted: Mon Nov 28, 2011 11:42 am
Barry that pump will do fine right where you have it set now. Only concern I would have is that the seals may need replacing more frequently than with gas. I know that gdmii usually went through a couple of those shaft seals per season on Methanol.
