QFT metering Blocks
http://motorsportsvillage.com/forum/viewtopic.php?f=21&t=8641
Author:  nomad [ Tue Oct 11, 2011 8:53 pm ]
Post subject:  QFT metering Blocks
I have in my possesion a pair of the green QFT 2 circuit blocks. I also own a pair of the red QFT 2 circuit 3 emulsion blocks. Soooooo.....I thought I'd pop out the mainwell plugs to see whats in there. Both blocks have identical mainwells which a #2 tapered reamer is too large.
The green block emulsions are .027, blank. .027, and blank. Anti-siphons are also .027. Mainwell exits are .160. I really thought that these blocks would be a little more special than just anodized green and a fourth emulsion.
Author:  jmarkaudio [ Tue Oct 11, 2011 10:04 pm ]
Post subject:  Re: QFT metering Blocks
But the green is cool, right? :-
Author:  ron [ Wed Oct 12, 2011 8:27 am ]
I have a set of green QF blocks that are about 3 years old and they measure, mainwell .182 no taper, cross exit is .160, eholes and anti siphon are .028, top to bottom are, open, blank, open, blank, came with a .043 IFR at top and a PVCR of .073.
Author:  ajcasini [ Wed Oct 12, 2011 3:05 pm ]
I have seen this as well. The original blocks were the ones described above. They changed their design on the newer style. They are a little different than the red blocks however will not work on much more than a 750 carb. I have run the new style blocks on a couple 750's and they work very well. The combos are mile SBC running 11.90's and 11.60's. I drill the main wells for anything bigger than 750.
QFT Green Blocks
Main Well .164 - .187
Idle Well .096
Cross Channel .161
PVCR .073
Emulsion Blank-.028-Blank-.028
Kill Bleed .028
IFR .043
QFT Red Gas Blocks 34-4
Main Well .158-.180 Taper
Idle Well .096
Cross Channel .140
PVCR .055
Emulsion .025-.025-.025-.025
Kill Bleed .028
IFR .035
Author:  Ken0069 [ Wed Oct 12, 2011 4:03 pm ]
QFT Green Blocks
Idle Well .096
Cross Channel .161
PVCR .073
Kill Bleed .028
IFR .043
Idle Well .096
Cross Channel .140
PVCR .055
Kill Bleed .028
IFR .035
So are the green blocks suppose to be for E85 then? :-k
I've got a set of their red blocks on an old style 8896 1050 Dominator but I can't remember the mapping for those. #-o
Author:  ajcasini [ Thu Oct 13, 2011 4:11 am ]
Yes the green blocks are QFT E85 calibrated metering blocks.
Author:  F636 [ Mon Jun 11, 2012 12:12 am ]
I have the QFT green blocks and I just pulled the main plugs and I can't get a #2 taper in there. I reamed it for the #2 but it also came with .043 ifr,. 076 pvcr, .028,p,.028,p and these were purchased in may '12. The cross channel is at least .160
