Author |
Message |
nomad
Posted: Tue Oct 11, 2011 8:53 pm |
Joined: Thu Jan 29, 2009 10:59 am Posts: 438 Location: Auburndale, Florida
I have in my possesion a pair of the green QFT 2 circuit blocks. I also own a pair of the red QFT 2 circuit 3 emulsion blocks. Soooooo.....I thought I'd pop out the mainwell plugs to see whats in there. Both blocks have identical mainwells which a #2 tapered reamer is too large.
The green block emulsions are .027, blank. .027, and blank. Anti-siphons are also .027. Mainwell exits are .160. I really thought that these blocks would be a little more special than just anodized green and a fourth emulsion.
jmarkaudio
Posted: Tue Oct 11, 2011 10:04 pm |
Joined: Mon Oct 29, 2007 7:07 pm Posts: 1422 Location: Florida
But the green is cool, right?
ron
Posted: Wed Oct 12, 2011 8:27 am |
I have a set of green QF blocks that are about 3 years old and they measure, mainwell .182 no taper, cross exit is .160, eholes and anti siphon are .028, top to bottom are, open, blank, open, blank, came with a .043 IFR at top and a PVCR of .073.
ajcasini
Posted: Wed Oct 12, 2011 3:05 pm |
I have seen this as well. The original blocks were the ones described above. They changed their design on the newer style. They are a little different than the red blocks however will not work on much more than a 750 carb. I have run the new style blocks on a couple 750's and they work very well. The combos are mile SBC running 11.90's and 11.60's. I drill the main wells for anything bigger than 750.
QFT Green Blocks Main Well .164 - .187 Idle Well .096 Cross Channel .161 PVCR .073 Emulsion Blank-.028-Blank-.028 Kill Bleed .028 IFR .043
QFT Red Gas Blocks 34-4 Main Well .158-.180 Taper Idle Well .096 Cross Channel .140 PVCR .055 Emulsion .025-.025-.025-.025 Kill Bleed .028 IFR .035
Ken0069
Posted: Wed Oct 12, 2011 4:03 pm |
Site Admin |
Joined: Tue Apr 18, 2006 6:38 am Posts: 11807 Location: Coming At Ya!
ajcasini wrote: I have seen this as well. The original blocks were the ones described above. They changed their design on the newer style. They are a little different than the red blocks however will not work on much more than a 750 carb. I have run the new style blocks on a couple 750's and they work very well. The combos are mile SBC running 11.90's and 11.60's. I drill the main wells for anything bigger than 750.
QFT Red Gas Blocks 34-4 Main Well .158-.180 Taper Idle Well .096 Cross Channel .140 PVCR .055 Emulsion .025-.025-.025-.025 Kill Bleed .028 IFR .035 So are the green blocks suppose to be for E85 then? I've got a set of their red blocks on an old style 8896 1050 Dominator but I can't remember the mapping for those.
ajcasini
Posted: Thu Oct 13, 2011 4:11 am |
Yes the green blocks are QFT E85 calibrated metering blocks.
F636
Posted: Mon Jun 11, 2012 12:12 am |
Joined: Sun Jul 10, 2011 6:32 pm Posts: 24 Location: Central Oregon
I have the QFT green blocks and I just pulled the main plugs and I can't get a #2 taper in there. I reamed it for the #2 but it also came with .043 ifr,. 076 pvcr, .028,p,.028,p and these were purchased in may '12. The cross channel is at least .160
_________________ Keith
