Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Holley Banjos
 Post Posted: Fri Jan 07, 2011 6:48 pm
Snow here so there won't be any testing around these parts! Pit Bitch and I are going to pull the tranny out of the Dodge tomorrow since I still don't have an intake to fit to the race engine yet. And that's a topic for another time! =P~ :-({|=
So have you got the O2 and stuff on the car now so you can get data?
 Post Posted: Fri Jan 07, 2011 7:39 pm
No Racepak this weekend, realized too late I needed a 12' VNet cable.
 Post Posted: Sat Jan 08, 2011 9:47 am
Sorry to hear about the Racepak. I'm looking forward to hearing how you make out with the regulator, etc.
I'm loving the new BLP website and on-line ordering. Place an order for some stuff last weekend but unfortunately I'm so far away that it doesn't show up until Monday. Oh well, I guess it's projects around the house for me this weekend. ](*,)
Mark Slayton
Rochester, NY
Quick Rod 130C
Super Comp 130C
 Post Posted: Sat Jan 08, 2011 3:53 pm
Good news, regulator made a big difference, now all I have to do is get enough fuel thru it. Right about where it would be on gas, responding to jet changes, had to drill some rears to see a big change. Race as is tonight, more details later...
 Post Posted: Sat Jan 08, 2011 3:59 pm
Awesome mark. Good luck tonight!
Mark Slayton
Rochester, NY
Quick Rod 130C
Super Comp 130C
 Post Posted: Wed Feb 02, 2011 8:43 pm
Got banjos and boosters from BLP today and got bad news just a few minutes ago. These banjos are a POS!! The damn holes in them are drilled off center of the leg that attaches to the carb body. I just tried to drill one out and the bit went out the side wall a quarter inch in?? DAYUMN IT!!!!
Screw this! I'm going to send these things back and probably work the 34-36 set I have that are already drilled out to what I need and grind the flair off them. These ones that BLP is selling must be some of that "Genuine Holley" crap like the ones I got a month or so ago from Autozone! JUNK! =P~ And I was ready to rock and roll on this thing?? [-(
 Post Posted: Wed Feb 02, 2011 9:18 pm
The only thing the Holley castings are probably good for is to use in the old bodies after you cut the sides to center them. The ones I used for the Davinci 1050 I fixed for a friend were like that. I'm going down in the AM, I'll see what they do for methanol and see if they have something better. They really need a wider slot in the body with a wider banjo for methanol, I'd say .300 should do it.
 Post Posted: Wed Feb 02, 2011 11:18 pm
Mark I sent Joe an Email just a bit ago requesting a return authorization and telling him what the problem is. I've got a set of Holley 34-36 flair banjos that I drilled out to .234 back a couple of years ago and all went well with those. Use the same setup method on these new ones that I used on the 34-36s and it's a no go because the hole isn't straight with the banjo body. I use that hole with a drill bit in the chuck to set them up in the vise so I reference off that existing hole. If the hole isn't in there straight, then I'm screwed.
