 Post Posted: Fri Jan 04, 2013 5:24 pm
Here's an article written back in 2003 in regard to taxes written by Daniel J. Mitchell, PHD
I've often heard the expression that, "Those who do not know history are destined to repeat it!" That may apply to things we see taking place today.
http://www.heritage.org/research/report ... -tax-rates
Quote:
There is a distinct pattern throughout American history: When tax rates are reduced, the economy's growth rate improves and living standards increase. Good tax policy has a number of interesting side effects. For instance, history tells us that tax revenues grow and "rich" taxpayers pay more tax when marginal tax rates are slashed. This means lower income citizens bear a lower share of the tax burden - a consequence that should lead class-warfare politicians to support lower tax rates.
Conversely, periods of higher tax rates are associated with sub par economic performance and stagnant tax revenues. In other words, when politicians attempt to "soak the rich," the rest of us take a bath. Examining the three major United States episodes of tax rate reductions can prove useful lessons.
1) Lower tax rates do not mean less tax revenue.
The tax cuts of the 1920s
Tax rates were slashed dramatically during the 1920s, dropping from over 70 percent to less than 25 percent. What happened? Personal income tax revenues increased substantially during the 1920s, despite the reduction in rates. Revenues rose from $719 million in 1921 to $1164 million in 1928, an increase of more than 61 percent.
According to then-Treasury Secretary Andrew Mellon:
The history of taxation shows that taxes which are inherently excessive are not paid. The high rates inevitably put pressure upon the taxpayer to withdraw his capital from productive business and invest it in tax-exempt securities or to find other lawful methods of avoiding the realization of taxable income. The result is that the sources of taxation are drying up; wealth is failing to carry its share of the tax burden; and capital is being diverted into channels which yield neither revenue to the Government nor profit to the people.
The Kennedy tax cuts
President Hoover dramatically increased tax rates in the 1930s and President Roosevelt compounded the damage by pushing marginal tax rates to more than 90 percent. Recognizing that high tax rates were hindering the economy, President Kennedy proposed across-the-board tax rate reductions that reduced the top tax rate from more than 90 percent down to 70 percent. What happened? Tax revenues climbed from $94 billion in 1961 to $153 billion in 1968, an increase of 62 percent (33 percent after adjusting for inflation).
According to President John F. Kennedy:
Our true choice is not between tax reduction, on the one hand, and the avoidance of large Federal deficits on the other. It is increasingly clear that no matter what party is in power, so long as our national security needs keep rising, an economy hampered by restrictive tax rates will never produce enough revenues to balance our budget just as it will never produce enough jobs or enough profits… In short, it is a paradoxical truth that tax rates are too high today and tax revenues are too low and the soundest way to raise the revenues in the long run is to cut the rates now.
The Reagan tax cuts
Thanks to "bracket creep," the inflation of the 1970s pushed millions of taxpayers into higher tax brackets even though their inflation-adjusted incomes were not rising. To help offset this tax increase and also to improve incentives to work, save, and invest, President Reagan proposed sweeping tax rate reductions during the 1980s. What happened? Total tax revenues climbed by 99.4 percent during the 1980s, and the results are even more impressive when looking at what happened to personal income tax revenues. Once the economy received an unambiguous tax cut in January 1983, income tax revenues climbed dramatically, increasing by more than 54 percent by 1989 (28 percent after adjusting for inflation).
According to then-U.S. Representative Jack Kemp (R-NY), one of the chief architects of the Reagan tax cuts:
At some point, additional taxes so discourage the activity being taxed, such as working or investing, that they yield less revenue rather than more. There are, after all, two rates that yield the same amount of revenue: high tax rates on low production, or low rates on high production.
2) The rich pay more when incentives to hide income are reduced.
The share of the tax burden paid by the rich rose dramatically as tax rates were reduced. The share of the tax burden borne by the rich (those making $50,000 and up in those days) climbed from 44.2 percent in 1921 to 78.4 percent in 1928.
Just as happened in the 1920s, the share of the income tax burden borne by the rich increased following the tax cuts. Tax collections from those making over $50,000 per year climbed by 57 percent between 1963 and 1966, while tax collections from those earning below $50,000 rose 11 percent. As a result, the rich saw their portion of the income tax burden climb from 11.6 percent to 15.1 percent.
The Reagan tax cuts
The share of income taxes paid by the top 10 percent of earners jumped significantly, climbing from 48.0 percent in 1981 to 57.2 percent in 1988. The top 1 percent saw their share of the income tax bill climb even more dramatically, from 17.6 percent in 1981 to 27.5 percent in 1988.
Harmful Spending & Complexity
Lower tax rates are important, but they are not the only critical issue. Both the level of government spending and where that money goes are very important. And even when looking only at tax policy, tax rates are just one piece of the puzzle. If certain types of income are subject to multiple layers of tax, as occurs in the current system, that problem cannot be solved by low rates. Similarly, a tax system with needless levels of complexity will impose heavy costs on the productive sector of the economy.
This WebMemo is excerpted from the author's, Daniel J. Mitchell's, Backgrounder, The Historical Lessons of Lower Tax Rates, published July 19, 1996. The original publication, found here, contains footnotes and numerous charts.
 Post Posted: Tue Jan 08, 2013 8:01 pm
Why does the left only see revenue increased by picking our pockets? If they make an environment where people would want to take a chance on a small business then those companies would pay tax and add to the revenue. The way it is now no one wants to take a chance to expand or invest into are economy. I see a lot of people doing everything under the table. Everyone knows are Credit rating is going in the Sh**ter. Our housing market is going to stay stagnate. I guess this is how they change capitalism in one fail swoop. By destroying jobs and making us all poor. I see wages for Jobs that are the same as they were ten years ago. So we are all on the same level. If you think it was Bush's fault. You are partly right, he was a progressive too. So can we now admit that they are Socialist's and not dance around it with a new labels and pretending to be on the cutting edge.
