Post new topic Reply to topic  [ 444 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 30  Next
 Post Posted: Sun May 29, 2016 2:50 pm
How to rebut climate hysteria in a few easy steps
Written by Steven Capozzola, 23 May 2016.
http://www.climatechangedispatch.com/ho ... steps.html
Quote:
It’s lonely being a “climate skeptic.” At social gatherings, you’re likely to be the lone outcast if you say you “don’t believe in catastrophic global warming.” Of course, what you really mean is, you don’t believe that carbon dioxide (CO2) emissions are driving contemporary warming. Regardless, it’s not the sort of thing people want to hear at parties. However, listed below are some possible responses to typical climate statements and questions that may pop up.
You don’t believe in global warming?
Yes, I do. The Earth has warmed by roughly 0.8 degrees Celsius since the late 1800s.
You don’t believe in climate change?
Yes, I do. The Earth’s climate has changed multiple times, just in the past 1,000 years.
CO2 levels are rising and the Earth is warming.
CO2 concentrations have risen slightly over the past century or so, to 0.04% of the earth’s atmosphere. At the same time, though, solar output has increased tremendously. This significant increase in solar activity—the most in as much as 2,000 years—is likely to be the key driver of 20th century warming.
But CO2 levels are the highest in 800,000 years.
CO2 levels in the atmosphere are currently among the lowest ever recorded on the planet. The past 800,000 years is a convenient timeframe, however, since the earth has undergone repeated glacial cycles in that time—which has progressively lowered atmospheric CO2.
CO2 is a greenhouse gas. More CO2 means more warming.
CO2 possesses a major limitation as a greenhouse gas. As demonstrated in laboratory studies, CO2 exponentially loses heat-trapping capacity as its concentration increases. This happens because, even in small quantities, CO2 quickly becomes opaque to a certain spectrum of infrared radiation. It rapidly absorbs all of the infrared radiation it can, which means that adding additional quantities of CO2 will not contribute any meaningful warming. CO2 is also a “well-mixed gas,” which means that its concentrations are distributed throughout the atmosphere. Consequently, its heat-trapping function is essentially saturated throughout the troposphere and stratosphere.
But higher CO2 levels mean higher temperatures? I saw that graph in ‘An Inconvenient Truth’.
Al Gore left out a key point when citing the parallel relationship between historical levels of CO2 and temperature. Carbon dioxide dissolves in water, and cold water can hold more CO2 than warm water. When the climate cools, the oceans gradually cool, slowly drawing in more CO2 and lowering atmospheric CO2 content. When the climate warms, as seen at the start of the most recent interglacial period roughly 18,000 years ago, the oceans gradually release CO2. (This is the reason why a bottle of soda kept in hot sunlight will leak or burst— because the warmer soda water is no longer able to hold all of the dissolved CO2.) When global temperatures change, CO2 concentrations follow along.
Scientists say that CO2 is warming the Earth.
Yes, CO2 is a greenhouse gas, and it helps maintain warmth in the atmosphere. But as noted above, CO2’s heat-trapping function is essentially saturated by the current level of 0.04 percent. Furthermore, climate models actually project that most of the presumed “man-made” warming will come from an increase in atmospheric water vapor. The principal idea of “anthropogenic global warming” is that the small amount of additional warming contributed by CO2 (before it becomes saturated) will cause more water vapor to enter the atmosphere. Since water vapor is the primary greenhouse gas of the atmosphere (and is responsible for roughly 80 percent of the “greenhouse effect”), this water vapor will create positive feedback for further warming.
Unfortunately, the theory disregards the cooling feedback caused by clouds (since atmospheric water vapor transitions to clouds). Cloud cover provides net cooling by reflecting solar radiation back into space, shading ground surfaces, and producing rain (precipitation not only cools surface temperatures but also scrubs atmospheric CO2).
But 97% of scientists believe in global warming?
What’s most amusing is that, truthfully, no one really knows how many scientists there are in the world. Or what they actually think of global warming. Or how many of them are scientists in relevant scientific disciplines. However, the “97% consensus” figure is actually a methodologically flawed statement. Only 32.6% of the papers studied in the infamous John Cook study actually stated a position endorsing anthropogenic (man-made) global warming. However, 97% of those said that “recent warming is mostly man-made.” And so what we have is a misleading statement that has become cited as fact.
Well, 2015 was the hottest year ever, and now 2016 is even hotter. Explain that?
The warming experienced in 2015-2016 is a direct result of the current El Niño.
El Niño is caused by global warming
El Niño is a naturally occurring phenomenon. It happens when prevailing winds start to fade after progressively “piling up” water in the western Pacific Ocean. This surplus, warmer water washes back over the eastern Pacific, releasing tremendous amounts of heat. 2015’s spike in temperatures was due to El Niño. It would be dishonest and inaccurate to claim that 2015’s increase in surface temperatures was simply due to man-made warming. Here’s more on the latest El Niño, and why even alarmists admit that it is not a manifestation of man-made warming.
The “pause in global temperatures” is just people denying that the Earth is getting hotter and hotter
Satellite measurements from both UAH-Huntsville and RSS clearly show the “pause” in global temperatures (I.e. a net flatlining of temperatures over the past 15-20 years.) The current El Niño is already fading, and one can reasonably expect to see a drop-off in temperatures. Since 1950 with 11 of the last 15 strong El Niño events flipped to a La Niña. More significantly, the pause has been the subject of numerous debates and research papers. Climate alarmists don’t deny that it has happened, they just offer various explanations. Even a February 2016 paper co-authored by Michael Mann shows that there was indeed a global warming pause.
There is no “pause” in global warming
There is real concern as to the accuracy and reliability of recent temperature measurements being reported by NOAA. Last year, NOAA adjusted temperatures downward in the last century to make the last 15 years appear warmer. Magically, they “erased” the pause. By including measurements of seawater temperatures taken from the engine manifolds of ocean-going vessels, they essentially cooled the past to warm the present. Here’s an academic summary of papers that quickly debunked NOAA’s “new” temperature findings. It’s interesting to note that it is NOAA’s revised measurements that are being used to make claims such as “warmest year ever” etc…
With the pause removed, NASA then quietly adopted NOAA’s “cooked” temperature record so that both agencies could make these “warmest ever” claims. Currently, NOAA is under House investigation for tampering with temperature data and colluding with activists to promote the Obama administration’s global warming agenda.
NOTE: These are simple points, based on elementary climate and geologic science. It would be helpful if more people studied the basic issues involved in the climate debate before accepting the alarmist rhetoric trumpeted by a media that thrives on sensationalism.
 Post Posted: Mon May 30, 2016 8:39 am
Well, temp data shows that El Nino is officially finished! Now lets see how cool and how long the coming La Nina will be!
May 2016 ENSO Update – The 2015/16 El Niño Has Reached Its End
Bob Tisdale May 30, 2016
https://wattsupwiththat.com/2016/05/30/ ... d-its-end/
Quote:
This post provides an update of many of the ENSO-related variables we presented as part of the 2014-15 El Niño Series and for the 2015/16 El Niño series.
INTRODUCTION
In the recent post Say Good-Bye to the 2015/16 El Niño, we illustrated and discussed how the weekly sea surface temperature anomalies of the NINO3.4 region of the equatorial Pacific had dropped below NOAA’s +0.5 deg C threshold for El Niño conditions for the week centered on May 18th. Weekly sea surface temperature anomalies for that region are now below zero.
We noted in the April update that both Australia’s Bureau of Meteorology (BOM) and the U.S.’s NOAA have issued La Niña alerts for the ENSO season of 2016/17. (BOM notice is here, and NOAA advisory is here.) Sea surface temperature anomalies for the equatorial Pacific are rapidly moving in the direction.
The questions now: If a La Niña forms and persists, how strong with the 2016/17 La Niña be? Will it last for a single-season, or will it be a multiyear La Niña like the 1998-01 La Niña that followed the 1997/98 El Niño, or will there be back-to-back La Niñas like we saw in 2010/11 and 2011/12 (See the current version of NOAA’s Oceanic NINO Index) and in 2007/08 and 2008/09 when NOAA was using the ERSST.v3b data for its Oceanic NINO Index)?
Back to your regularly scheduled update…
ENSO METRIC UPDATES
This post provides an update on the progress of the evolution and decay of the 2015/16 El Niño with monthly data through the end of April 2016, and for the weekly data through late-May, 2016. The post is similar in layout to the updates that were part of the 2014/15 El Niño series of posts here and the series of posts about the 2015/16 El Niño here. The remainder of the post includes a bunch of illustrations and a gif animation, so it might take a few moments to load on your browser. Please click on the illustrations to enlarge them.
Included are updates of the weekly sea surface temperature anomalies for the four most-often-used NINO regions. Also included are a couple of graphs of the monthly BOM Southern-Oscillation Index (SOI) and the NOAA Multivariate ENSO Index (MEI).
For the comparison graphs we’re using the El Niño evolution years of 1997/98 and 1982/83 where possible (the two strongest El Niño events during recent decades) as references for 2015/16.
Also included in this post are evolution comparisons using warm water volume anomalies and depth-averaged temperature anomalies from the NOAA TOA project website.
Then, we’ll take a look at a number of Hovmoller diagrams comparing the progress so far for the 2015/16 El Niño to the El Niños of 1982/83 and 1997/98.
A TON of graphs and other data along with the complete article can be seen HERE
 Post Posted: Wed Jun 01, 2016 11:02 am
Masato Mori’s Harsh Winter/Shrinking Arctic Sea Ice Hypothesis Flops, Brand New Study Shows!
By P Gosselin on 1. June 2016
Quote:
Some 15 years ago we were told that snow and ice in the wintertime would be things of the past.
Then Europe and North America experienced a series of harsh winters and climate scientists, turning on a dime, suddenly declared them the result of global warming.
Now that claim too is turning out to be a farce as well.
Flopped hypothesis: Cold winters not the consequence of shrinking Arctic sea ice
By Dr. Sebastian Lüning und Prof. Fritz Vahrenholt
(German text translated/edited by P Gosselin)
Quote:
Do you recall how the experts wanted to tell us that cold winters were linked to global warming? For example Spiegel Online wrote on 27 October 2014:
Quote:
Weather bridge: Ice melt in the Arctic cooling winters in Europe
Climate scientists have discovered a meteorological remote link: When the sea ice melts in the Arctic, atmospheric currents get shifted – winters in Europe and Asia get cooler.
According to a study, ice melt over the past decades has led to especially harsh winters in Europe and Asia. Observations show that the cold winters could be linked with the retreat in Arctic sea ice, which has been happening over the past decades. Scientists led by Masato Mori of the Japanense University of Tokyo have discovered that the retreat of sea ice in the Arctic Barents-Kara Sea favor atmospheric currents that lend to cold in Europe and Asia. These atmospheric patterns that are called ‘blocking situations’ that serve to convey cold air to Europe and Asia and cause harsh winters there, reported the scientists in the journal “Nature Geoscience”.
A regrettable scientific knee-jerk reaction – as it would be exposed just a year and half later.
A team of scientists of the University of Colorado Boulder and the NOAA led by Lantao Sun examined the mechanism more closely on 25 May 2016 in a new study in the Geophysical Research Letters. They were unable to confirm the relationship between sea ice melt and cold continental winters. The cold winters were neither explainable by the shrinking Arctic sea ice, nor by anthropogenic factors, the scientists found. A pronounced and underestimated natural climate variability is much more at play here.
The abstract for this important paper follows:
Quote:
What caused the recent “Warm Arctic, Cold Continents” trend pattern in winter temperatures?
The emergence of rapid Arctic warming in recent decades has coincided with unusually cold winters over Northern Hemisphere continents. It has been speculated that this “Warm Arctic, Cold Continents” trend pattern is due to sea ice loss. Here we use multiple models to examine whether such a pattern is indeed forced by sea ice loss specifically and by anthropogenic forcing in general. While we show much of Arctic amplification in surface warming to result from sea ice loss, we find that neither sea ice loss nor anthropogenic forcing overall yield trends toward colder continental temperatures. An alternate explanation of the cooling is that it represents a strong articulation of internal atmospheric variability, evidence for which is derived from model data, and physical considerations. Sea ice loss impact on weather variability over the high-latitude continents is found, however, to be characterized by reduced daily temperature variability and fewer cold extremes.
This is a nice example of how we should not immediately believe everything our experts say and why critique and skepticism are completely justified.
- See this article HERE
 Post Posted: Sat Jun 04, 2016 7:40 pm
Book banning? What's next, burning "deniers" at the stake? :-
Portland school board bans climate change-denying materials
Created on Thursday, 19 May 2016 02:00 | Written by Shasta Kearns Moore
http://portlandtribune.com/sl/307848-18 ... -materials
Quote:
In a move spearheaded by environmentalists, the Portland Public Schools board unanimously approved a resolution aimed at eliminating doubt of climate change and its causes in schools.
“It is unacceptable that we have textbooks in our schools that spread doubt about the human causes and urgency of the crisis,” said Lincoln High School student Gaby Lemieux in board testimony. “Climate education is not a niche or a specialization, it is the minimum requirement for my generation to be successful in our changing world.”
The resolution passed Tuesday evening calls for the school district to get rid of textbooks or other materials that cast doubt on whether climate change is occurring and that the activity of human beings is responsible. The resolution also directs the superintendent and staff to develop an implementation plan for “curriculum and educational opportunities that address climate change and climate justice in all Portland Public Schools.”
Bill Bigelow, a former PPS teacher and current curriculum editor of Rethinking Schools, a magazine devoted to education issues, worked with 350PDX and other environmental groups to present the resolution.
“A lot of the text materials are kind of thick with the language of doubt, and obviously the science says otherwise,” Bigelow says, accusing the publishing industry to bowing to pressure from fossil fuels companies. “We don’t want kids in Portland learning material courtesy of the fossil fuel industry.”
In board testimony, Bigelow said PPS’ science textbooks are littered with words like might, may and could when talking about climate change.
“ ‘Carbon dioxide emissions from motor vehicles, power plants and other sources, may contribute to global warming,’ ” he quotes Physical Science published by Pearson as saying. “This is a section that could be written by the Exxon public relations department and it’s being taught in Portland schools.”
Bigelow is also the co-author of a textbook on environmental education, A People’s Curriculum for the Earth. Asked if this resolution will cause the district to buy new textbooks, such as his book, Bigelow said Rethinking Schools is a nonprofit, not a money-maker.
“What we’re asking for is not: Buy new stuff,” he said. “What we’re looking for is a whole different model of curriculum development and distribution.”
Bigelow said the district already has climate-change literacy curriculum, such as at Sunnyside Environmental School, and he wants that knowledge to spread.
School board member Mike Rosen introduced the resolution. He also leads NW Ecoliteracy Collaborative, a project focused on environmental curriculum standards. However, he says that work has been on hold.
“I have become concerned about its ability to make progress and not have a conflict with being a school board member,” Rosen said, noting that he is now instead working part-time for the Audubon Society of Portland. “I don’t want there to be a conflict between my school board work and this nonprofit.”
 Post Posted: Tue Jun 14, 2016 10:09 pm
Powerful Natural Oceanic Factor Confirmed ….Global Surface Temperatures Continue Their Fall!
By P Gosselin on 14. June 2016
Quote:
Schneefan at his site here writes about the unusually wet weather Europe has been experiencing lately. This has to be upsetting to global climate modelers and scientists, who years ago claimed Europe would have to expect hot, dry summers involving severe periods of droughts.
That prediction has turned out to be totally wrong. The very opposite has in fact occurred.
The reason for the recent wet conditions are likely in part due to the post (natural) ENSO activity of the past months, which have disrupted weather patterns, Schneefan suspects.
On global temperature we see the clear impacts of the oceanic ENSO. Schneefan writes the following at his site:
“The regional development in Europe is affected by the rash global cooling following the El Niño peak in global temperatures in February 2016.
The rash cooling is also continuing in June 2016 and will lead to further high precipitation in places like Australia.
See more on this at THIS website.
 Post Posted: Thu Jun 16, 2016 5:01 pm
WATCH AND HEAR PROF RICHARD LINDZEN DEMOLISH 'GLOBAL WARMING' SCAM
Posted 15 June 2016
THIS VIDEO MADE BY PRAGER UNIVERSITY, A PRIVATE ON-LINE INSTRUCTIONAL FACILITY IN AMERICA, FEATURES DISTINGUISHED M.I.T. SCIENTIST, PROFESS RICHARD LINDZEN, IN WHAT IS PROBABLY THE MOST SUCCINCT AND COMPELLING VISUAL REBUTTAL EVER OF THE 'GLOBAL WARMING' SCAM.
Watch and listen HERE
 Post Posted: Sat Jun 18, 2016 2:49 pm
Is Climate Science Settled Because It Cannot Be Settled?
by Dr. Tim Ball
June 18, 2016
Quote:
Al Gore even made some hardened liberal journalists sit up and question when in 2007 he told a joint session of the House Energy Committee and The Senate Environment Committee that the climate debate was over, “the science was settled”. The journalists knew, as any moderately informed person does, that science is never settled. But, what does “settled” mean in this context? The most reasonable definition is linked directly to a simple definition of science, namely the ability to predict. If you can’t predict then your science is wrong, as Feynman and others made clear. Failed predictions prove that the science isn’t settled. Gore and the supporters of the Intergovernmental Panel on Climate Change (IPCC) version of anthropogenic global warming (AGW) claim the science is settled, but their climate predictions (projections) are consistently wrong. The problem is wider because the weather predictions of national weather agencies who are, through the World Meteorological Organization (WMO) the IPCC, don’t work either.
Interesting read but kinda long. See the full article HERE
 Post Posted: Tue Jun 21, 2016 7:12 pm
Global temperatures are heading downward, and fast
Anthony Watts / 9 hours ago June 21, 2016
Quote:
It’s no surprise to us that the “monster” El Niño of 2015/2016 created a very large global temperature spike, after all, that’s what the natural process that creates the phenomenon results in due to the Pacific ocean near the Equator not being able to dissipate heat to space as effectively as it usually does. NOAA says that “ENSO is one of the most important climate phenomena on Earth due to its ability to change the global atmospheric circulation, which in turn, influences temperature and precipitation across the globe. ”
But, as they say, “what goes up, must come down”. NOAA has this to say about the current state:
Quote:
After dominating the tropical Pacific for more than a year, El Niño ended in May 2016. Near- or below-average temperatures existed in 3 out of 4 ENSO monitoring regions of the tropical Pacific. And for the first time in 2016, wind and air pressure patterns were consistent with neutral conditions. There’s a 75% chance that La Niña will develop by winter. NOAA’s next ENSO update will be released on July 14.
See this complete article including many links and graphs HERE
 Post Posted: Wed Jun 29, 2016 8:00 pm
Arizona Historic Heatwave Fraud
Posted on June 29, 2016 by tonyheller
http://realclimatescience.com/2016/06/a ... ave-fraud/
Quote:
Two weeks ago, experts announced an historic heatwave in Arizona. They said that “Lying About Science For Politics Is Evil” – which is exactly what they are doing. In fact, June has been just about average and much cooler than 1896.
The June heatwave of 1896 was much hotter and longer than this year’s two day spike.
This year’s heatwave was just about average, and nowhere near a record.
With climate experts, it is all lies, all the time. And then they accuse the honest people of being liars.
 Post Posted: Fri Jul 01, 2016 10:13 am
UAH Global Temperature Update for June 2016: +0.34 deg. C
July 1st, 2016 by Roy W. Spencer, Ph. D.
Second largest 2-month drop in global average satellite temperatures.
Largest 2-month drop in tropical average satellite temperatures.
Quote:
The Version 6.0 global average lower tropospheric temperature (LT) anomaly for June, 2016 is +0.34 deg. C, down 0.21 deg. C from the May value of +0.55 deg. C
This gives a 2-month temperature fall of -0.37 deg. C, which is the second largest in the 37+ year satellite record…the largest was -0.43 deg. C in Feb. 1988.
In the tropics, there was a record fast 2-month cooling of -0.56 deg. C, just edging out -0.55 deg. C in June 1998 (also an El Nino weakening year).
The rapid cooling is from the weakening El Nino and approaching La Nina conditions by mid-summer or early fall.
The June anomaly is well below the dashed red line which represents the average cooling rate required for the rest of 2016 to tie 1998 as the warmest year in the satellite record. So far my prediction that 2016 will end up being a new record warm year is not shaping up too well…the cooling we are seeing in the troposphere really is spectacular.
As usual, Dr Roy has a TON of graphs and links so please click HERE to go to his site to see the entire article.
 Post Posted: Tue Jul 05, 2016 9:12 am
Looks like there's hope down under!! We should be so lucky!!
Green Panic: “Deniers” may hold the Balance of Power in the Aussie Senate
Eric Worrall / 13 hours ago July 4, 2016
Quote:
Greens are panicking in Australia in the wake of the recent cliffhanger Federal Election, as the likelihood grows that climate skeptic Pauline Hanson, who has repeatedly demanded a Royal Commission into Climate Change, will control the balance of power in the new Australian Senate.
Australia Is Being Swamped By Climate Change Deniers
Quote:
With Pauline Hanson looking certain to return to parliament, there’s never been a worse time to be the Great Barrier Reef, writes Liz Conor.
Fellow Austraiyans. If you are reading me now it means that I have become murderous.
Murderously, apoplectically incensed.
Pauline Hanson appears to have picked up a spot in our Senate at the time of writing, possibly even two or more. She will represent Queensland in our House of Review, where our nation’s proposed laws are rejected or amended. And it’s not a three-year term. Unless Turnbull (potentially newly rolled into Prime Minister Morrison out of revenge for the LNP’s slashed majority) finds some other spurious reason to call a double dissolution, Hanson’s term is Six. Six. Six.
Hanson will make extravagant use of the Senate’s committee system, already proposing royal commissions into Islam and climate science. How in chrissname do you conduct an inquiry into one of the three major world religions? Imagine the terms of reference. Are there too many believers? Should they perform the pilgrimage to Mecca? Are Humans superior to Angels? Will the Australian Royal commission into erm, Islam require the seventh-century originals of its foundational documents be tendered – the Qur’an, hadith and tafsir?
And why does Hanson even have an opinion on climate science? Why are racists climate deniers? Does Hanson have doubts about enlightenment empiricism? Logical positivism? The verification of Authentic Knowledge? Or has she, like most climate deniers and obstructers, featherbedded her campaign with undeclared funds from fossil fuel conglomerates?
believe we are in danger of being swamped by Caucasians, tax evasions and Australasians. They have their own culture and religion, form ghettos, and do not assimilate.
We are bringing in people from Oxley at the moment. There was a huge amount coming to our polling booths, and they’ve got diseases, they’ve got BIAS.
Read more: https://newmatilda.com/2016/07/04/austr ... e-deniers/
 Post Posted: Sun Jul 10, 2016 8:51 am
A special thanks to Tony Heller, webmaster of realclimatescience.com for making sure that copies of past raw temperature data are saved and unmolested by NOAA and NASA! O:)
July 10, 1913 – Hottest Day Ever
Posted on July 10, 2016 by tonyheller
Quote:
On this date in 1913, California reached 134 degrees during a week when every day was over 127 degrees This was the hottest officially recognized temperature ever recorded on Earth.
The heat wasn’t confined to California or to July. The US midwest had their second longest heatwave on record in August 1913, with 20 consecutive days over 100 degrees at Clinton, Missouri.
CO2 was at very low levels in 1913, indicating that heat waves have nothing to do with CO2 levels. This of course doesn’t stop government funded scientists from lying about the topic, like they do about every other climate topic.
And according to NASA, 1913 was one of the ten coldest years on record. O:)
As usual Tony has many graphs to back up his statements that can bee seen HERE
 Post Posted: Thu Jul 14, 2016 5:38 am
Already 240 Published Papers In 2016 Alone Show the “97% Climate Consensus” Is A Fantasy
Anthony Watts / 23 hours ago July 13, 2016
Quote:
From Friends of Science Newsletter by Albert Jacobs
Kenneth Richard has compiled a list of 770 papers published since January 1, 2014 that contradict the IPCC consensus statement, see HERE.
This includes 240 papers published during the first half of 2016, as shown HERE.
The list of papers includes 43 on solar influences, 27 on natural ocean oscillation, 2 on Rossby waves, 3 on ozone, 6 on the small effect of CO2, 11 on natural variability, 11 on clouds and aerosols, 3 on CO2 stratospheric cooling, 15 on past climates, 4 on settled science, 19 on Climate Model Unreliability, 2 on urban warming, 6 on volcanic forcing, 2 on warming oceans, 7 on miscellaneous topics, 2 on forest fires, 2 on cold vs heat deaths, 6 on climate policy, 7 on extreme weather, 20 on polar ice, 9 on sea level rise, 12 on ocean acidification, 2 on hurricanes, 4 on droughts, 3 on natural climate catastrophe, 7 on greening and crop yields and 1 on low climate sensitivity.
 Post Posted: Sat Jul 16, 2016 11:01 am
Just finished watching this video put out by Tony Heller of StevenGoddard.com and realclimatescience.com fame. It's a long one but a good one and I consider it a "must see" if you're a true believer that the global warming/climate change fiasco is a FRAUD!
My Temperature Record Presentation In Omaha
Posted on July 14, 2016 by tonyheller
Quote:
On Saturday I gave this presentation to the Doctors For Disaster Preparedness in Omaha, Nebraska. A great group of very distinguished people and a fun town.
The presentation is long, but should prove to be a valuable resource in exposing the manipulation of data by government agencies. At the end, I dedicated it to my good friend Dr. Bill Gray.
See Tony's video presentation HERE!
You can download the presentation in PDF format here: Evaluating The Integrity Of Official Climate Records
We need to find someone in Congress strong enough to take this issue on. There is no reason for this scam to continue.
 Post Posted: Tue Jul 19, 2016 4:05 pm
Climate Skeptics Face Senate Inquisition
By Larry Bell
Monday, 18 Jul 2016 09:29 AM
http://www.newsmax.com/LarryBell/compan ... z4Emacawls
Quote:
Galileo has lots of modern-day companions. Woe be unto those who dare to doubt that the sun orbits around Planet Gore as pontiffs of doom have decreed.
That’s exactly the 17th century time warp scenario that played out last week on the Senate floor as Chief Inquisitor Sheldon Whitehouse, D-R.I., and 18 fellow jurists intoned judgments against dozens of organizations for sins of “denial blocking action on climate.” Most of those sinful deniers are nonprofit conservative think tanks, including several that I am sinfully very proud to associate with.
And nope, like most of those other sinful deniers, I don’t get paid to think in any tank.
The purpose of this floor show was to vilify and intimidate a hit list for the Democratic drafting committee’s unanimously adopted platform calling for the Department of Justice to investigate those who disagree with their jihad against climate alarm-driven energy regulatory policies.
That position follows legal actions against ExxonMobil by attorneys general from California, Massachusetts, New York, and the Virgin Islands which demand that the company turn over decades of correspondence with a lengthy fishing trip listing of other suspected climate crisis skeptics.
The drafting committee ordained that all fossil fuel use must be banished by 2050. Its high priests include noted alarmist climate activist and 350.org co-founder Bill McKibben and Carol Browner, who directed President Barack Obama’s White House Office of Energy and Climate Change Policy.
Their summary report states: “Moving beyond the ‘all of the above’ energy approach in the 2012 platform, the 2016 platform draft re-frames the urgency of climate change as a central challenge of our time, already impacting American communities and calling for generating 50 percent clean electricity within the next ten years.”
They are already making great strides. Just as the President Obama promised, in the interest of ending billions of years of climate change the coal industry, which has provided 18 percent of America’s primary fuel, is now bankrupt.
That’s only the beginning. While previously touting natural gas as a lower emission bridge fuel to renewables, Sierra Club’s “Beyond Dirty Fuels” campaign leader Lena Moffitt told S&P Global Market Intelligence: “We are doing everything we can to bring the same expertise that we brought to taking down the coal industry and coal-fired power in this country to taking on gas in the same way.”
The idea, of course, is to save America — the world — from dreaded climate change by switching away from “dirty” plant-fertilizing CO2 emissions to clean, renewable “alternatives."
In other words, by regulating companies that provide more than 80 percent of our primary energy out of business and raising subsidies sky-high for windmills and sunbeams that provide 4 percent, we will be able to reduce global temperatures by an estimated 0.03 degrees Celsius before the next century.
How do they know? Well, because that’s what “settled science” based upon infallible computer models and divine authority "consensus" tells us to believe.
Yes, even Armageddon doubters realize that climate really does change, and that global mean temperatures have been warming in fits and starts since the little ice age ended about 150 years ago. Nevertheless, despite ballyhooed “record high” atmospheric CO2 concentrations, other than entirely natural 1998 and 2015 ocean El Nino spikes, satellite and weather balloon measurements show no statistically-significant global warming for nearly two decades.
We’re also not supposed to pay any heed to U.S. surface records obtained from the most reliable thermometer stations — those not corrupted by local “heat island” influences such as instrument relocations, urban developments or other man-made changes — which show no appreciable warming over the past 80 years.
In addition, ignore the fact that there have been more all-time U.S. cold records than heat records since the 1940s. And don’t believe your lyin’ eyes that tell you regarding that “extreme weather” we’ve been warned about that no category 3-5 hurricanes have struck the U.S. coast since October 2005, setting a century-long record lull since 1900.
In fact, NOAA and even the U.N.’s alarmist IPCC have admitted that there have been no increases in the severity or frequency of droughts, floods, thunderstorms, or tornadoes in decades.
Nobel Physics laureate Ivar Giaever has called global warming (aka, climate change) alarmism a “new religion” . . . a temple built on grounds of faith rather than upon scientific foundations. In this church, all unfortunate events that occur are attributed to human causation. Eco-elitist doom prophets and profiteers perpetrate dogma and intimidation to extract offerings of penance in exchange for promised salvation from fossil-fueled hellfire.
Future historians will reflect upon this unscientific aberration of our age as highly reminiscent of a time nearly four centuries ago when Galileo hopelessly protested when forced to recant his direct observations,“and yet it moves.” Just as the sun doesn’t orbit around the earth, perpetual world climate changes don’t cycle around earthlings either.
Larry Bell is an endowed professor of space architecture at the University of Houston where he founded the Sasakawa International Center for Space Architecture (SICSA) and the graduate program in space architecture. He is the author of “Scared Witless: Prophets and Profits of Climate Doom”(2015) and “Climate of Corruption: Politics and Power Behind the Global Warming Hoax” (2012).
