 Post subject: Award video
 Post Posted: Sun Dec 19, 2010 10:14 am
Here is a shaky video of the NMC part of the NMCA awards. I took it with a camera so it isn't the best.
http://www.streetfire.net/video/nmca-nm ... 099168.htm
 Post subject: Re: Award video
 Post Posted: Sun Dec 19, 2010 10:54 am
Cool Video Steve! Glad to see you guys finish in the top 10!!
 Post Posted: Sun Dec 19, 2010 10:16 pm
Thanks Jody. It was a good time. How is your truck coming?
 Post Posted: Mon Dec 20, 2010 4:29 am
Truck is coming along slow because I have not been working on it.. #-o
I did get 2 new SFI flex plates and a new CSR starter.. the block too.
I have a list of things to do...
Rearend gears are broken again so it needs takin' out and I am going to have my machine shop guy setup the gears (maybe they will last that way)..
The trans is still on the stand half tore apart need to put it back together since there is nothing wrong with it. The Motor needs to come out and be tore apart to get ready to switch in to the new block. Also I am having a 3 gallon fuel cell made for up front, will need plumbing.
The old fuel system needs removed too. I have alot to do, but will have plenty of time.
I will start on it after New Years I guess... \:D/
 Post Posted: Mon Dec 20, 2010 6:22 am
Very cool Steve!!!!!!! \:D/ \:D/ And congratulations to both of you..
I always liked Bret as an announcer as he is one of the best along with the late Steve Evens(sp?)....
 Post Posted: Mon Dec 20, 2010 8:07 am
Jody just keep plugging away. Sounds like a lot of work but your going in the right direction. I think you might see some 5's this year \:D/ \:D/ \:D/ Are you going to stud the heads this time? If so don't forget the permatex thread sealer on the studs and run block sealer in the water when you first start it. Ask me how I know #-o :-# =;
Thanks Barry. Bret does a lot with the NMCA. he is the one that played a key role in getting our finals at Gateway last year. Now that Gateway is closed he will be at every race. One of my favorite announcers is Army Armstrong. 2 years ago he was inducted in the Kentucky Motorsports Hall of Fame that was held here in town (Chuck and I went to that one). The normal Announcer for the NMCA is Al Tucci, he is a riot.
 Post Posted: Fri Jan 07, 2011 12:43 pm
congrats to you both \:D/ \:D/
http://www.s10dragracer.com/
 Post Posted: Fri Jan 07, 2011 1:27 pm
Thanks Mark.
