 Post Posted: Sat Jan 24, 2009 12:35 pm
scoop wrote:
What tracks do you race at? Bob
In the past I've raced at 75/80, Mason Dixon, Cecil, MIR, US13, VMP, Atco, South Mountain and Maple Grove.
 Post Posted: Sat Jan 24, 2009 12:45 pm
The combination.
582 bbc, 4.600 bore x 4.375 stroke
Dart Big M block with .904 bushed lifter upgrade
Callies Magnum series II crank
Lunati Pro Billet rods
Diamond custom pistons, gas ported
15.45 to 1 static compression
Trend H-13 tool steel pins
Total Seal .043/.043/3mm ring pack
Brodix Head Hunter 377/383 cnc Oval heads with 2.400 x 1.860 titanium valves
PAC springs, titanium retainers
T&D shaft rockers with 1 piece intake stands, needle bearing tips and pressureized tip oiling
Manton Stage 5 7/16 x .120" pushrods
Jesel Belt drive
Custom Comp roller 283/302 @ .050, .891/.822 lift, 114 lsa, 112 icl, 7/4 swap
Crower severe duty lifters with Hippo, .904
Moroso 20385 Pro Eliminator pan with 22163 billet pump
Moroso sheet metal valve cover 68458
Brodix Head Hunter BM2017 intake
Pro Systems 1300XE carb
MSD crant trigger & distributor
ATI balancer & flexplate
Meziere 300 series water pump
To complete the engine totally I need to purchase the vacuum pump system (Star) and also the alternator setup (ECAE).
 Post Posted: Sat Jan 24, 2009 2:40 pm
10secBu wrote:
Thanks.
It's a 582. I'm hoping the car will run mid/upper 8's at 3350 lbs all motor.
You will go in the 8's i run in the 8's with a 540 in 3563lbs.
The last 1/4 mile pass when i junked my converter i went 9.01 with a bad trans and broke verter so ya you are in the 8's
 Post Posted: Sat Jan 24, 2009 5:03 pm
I have to say it will go faster if you get rid of that carb O:)  O:) IMO =;
 Post Posted: Sat Jan 24, 2009 6:00 pm
I'm  going 8.70's with a 970Hp 540 @ 3018 lbs.You'll be somewheres  in the 8's NO PROB!! BTW Mark70 nova is a dealer for Star products!!
 Post Posted: Wed Apr 01, 2009 8:50 pm
Nice Todd.Man you still have it! congrats.I miss my old boo 4sure.
