 Post subject: new combination for 2009
 Post Posted: Thu Jan 22, 2009 6:47 pm
Just some pics of the new engine combination for the 2009 season. Will also be swapping from a th400 to glide, new converter, driveshaft, gears, tires, headers, R&P steering conversion, etc.
http://www.qis.net/~geislert/582bbc1.JPG
There are 50 build pics, all you need to do is use the same link but change the image picture to 1 through 50 to see all the pics.
 Post Posted: Thu Jan 22, 2009 7:21 pm
Looks Good!!! how "Big" is it O:) ....Im juessin you want to pick up the pace a little =;
 Post Posted: Thu Jan 22, 2009 7:28 pm
Thanks.
It's a 582. I'm hoping the car will run mid/upper 8's at 3350 lbs all motor.
 Post Posted: Thu Jan 22, 2009 7:47 pm
WOW!!! 582 That will put my Beretta in the 7s O:)  O:)  O:)
 Post Posted: Thu Jan 22, 2009 7:48 pm
Should make between 1050 and 1100 hp.
Will know after it's dyno'd sometime before spring.
 Post Posted: Thu Jan 22, 2009 7:57 pm
Is that one of those 3 circuit carbs  =;  =;
 Post Posted: Thu Jan 22, 2009 9:00 pm
I suppose it is.  :-  =;
 Post Posted: Thu Jan 22, 2009 9:27 pm
im working on 3 curcuits right now, i have to go wipe the druel off my face.. =;  =;  =;
sweet motor. \:D/  \:D/  \:D/  \:D/
 Post Posted: Fri Jan 23, 2009 2:11 am
How much clearance have you got on the lifter cross link to the top of the lifter bore??  it looks very close
Looks very similar to what I have just built, are they the -3 Xtra O heads ?
Sam
 Post Posted: Fri Jan 23, 2009 6:35 am
The lifter tie bars are very close to the block, probably less than 1/8".
The heads are the 377/383cc Head Hunter MC's with 2.400 x 1.860 titanium valves.
 Post subject: Very nice
 Post Posted: Fri Jan 23, 2009 10:01 am
What intake is that, the Profiler?????  I hear lots of good things about that intake..  Oooops, never mind, I saw that it is a Brodix intake :-  Who's crank did you get?? and I love those heads with them hugh oval ports, and it looks like your avatar will need to be changed now to either 9secbu, or maybe even 8secbu!!!!! O:)   Looks real good, and it shoudl haul your mail darn good.  Good luck this year buddy. =;
Elky
 Post Posted: Fri Jan 23, 2009 10:36 am
Looks great  \:D/  \:D/  \:D/  \:D/  \:D/  \:D/  \:D/  \:D/
 Post Posted: Fri Jan 23, 2009 5:02 pm
Thanks guys. The crank is a Callies Magnum series II.
I'll post specs later this evening or this weekend.
 Post Posted: Sat Jan 24, 2009 9:45 am
Sweet Motor!!
 Post Posted: Sat Jan 24, 2009 12:33 pm
What tracks do you race at? Bob
