 Post Posted: Tue Apr 29, 2008 6:46 am
I'm a new member here and just wanted to share a couple pics of the car I built over the winter.
 Post Posted: Tue Apr 29, 2008 6:48 am
nice work . \:D/  \:D/
 Post Posted: Tue Apr 29, 2008 6:59 am
Thanks. I'm hoping to get it to the track on the 18th for some test & tune. Car weighed 2700 lbs. with a iron headed big block and ran 10.0's with a mild 454. This engine has Brodix heads and is a 468 with 13.5 to 1 compression. 2x3 tube frame, ladder bar w/ dana 60 4:88's and the complete interior is aluminum. I've been building this car since last Dec. and can't wait to see what it'll run.
mmmmmmmmm...... my sort of car, short wheel base & heaps of torque
have you run it yet or are you still sorting it out
regards
rod
The older I get the better I was
 Post Posted: Tue Apr 29, 2008 7:11 am
The car is done except for a problem I'm having getting the conveter to seat properly. Once I get that done, its ready to hit the track. I plan on running it the way it is a little until I get use to the car. I do have a couple of nitrous kits (one plate & one fogger) that I'd like to try at some point. Don't really plan on running the spray a lot but I do have a couple of grudge races coming up and do plan on using the spray for those. The heads are studded and the ring where gapped loose for the spray.
 Post Posted: Tue Apr 29, 2008 8:35 am
Very cool car  \:D/  \:D/  \:D/   best of luck to you.  Go fast and be safe!!
 Post subject: KRAZYKEN
 Post Posted: Tue Apr 29, 2008 12:50 pm
Nice ride
 Post Posted: Tue Apr 29, 2008 7:20 pm
Great looking wagon \:D/  \:D/  \:D/  \:D/
How much is steel and what did you use to block the windows? the front fenders look steel. Did those wheel wells help any?
 Post Posted: Tue Apr 29, 2008 7:34 pm
Thanks, unfortunately its all steel except for the hood. The nose comes off after removing 2 bolts and 2 pins but still don't know why the builder didn't go with fiberglass. Thankfully the windows are in frames and I pulled the glass ones out and cut the plastic to exactly the same dimensions. Slid the plastic ones up into the frames and riveted the bottoms to the door.  I'll have to see if they'll pass tech inspection.
Thanks, and you be safe too.
 Post Posted: Wed Apr 30, 2008 12:05 pm
very cool !!
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
Fleenor Racing Glides
"get one before one gets you"
 Post Posted: Wed Apr 30, 2008 8:01 pm
Thank you. I am dying to get this to the dragstrip and I'm hoping to get it there this coming weekend with a little bit of luck.
 Post Posted: Sat Aug 09, 2008 11:02 pm
nice woik =;
http://www.scrapmetalracing.com
