Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post Posted: Sat Nov 22, 2008 4:11 am
OK guys
now that i have got over my Lazy self & have regained my enthusiem in the car i thought it is worth a bit of an update to this thread
went to work this morning to try & get some work done while nobody was there
guess again:
Note to self,  do not leave car outside factory when working on race car as everybody knows what you are doing & you will spend all day opening the bloddy door to let friends in
thank good they make nice coffee
anyway after several interuptions i finally got a little work done
you can judge for yourself what got done
regards
rod
 Post Posted: Sat Nov 22, 2008 4:19 am
 Post Posted: Sat Nov 22, 2008 4:20 am
 Post Posted: Sat Nov 22, 2008 4:28 am
the pipes & collectors have all been HPC coated & are now on the engine atlast
can i keep up this motorvation ......
i went to the drags last weekend looking for a bit of motorvation & after sitting there until well after midnight i thought Monday i will be all keen to get it done but nothing happened untill Wednesday when i started to fire up again
at this rate i only have 2 full days work in it, 3 at the most
regards
rod
 Post Posted: Sat Nov 22, 2008 4:40 am
[img][img]http://i5.photobucket.com/albums/y172/rodrocket/Pontiac/Pontiac%20-%20drive%20train/DSC00279-1.jpg[/img]
transmission cooler is all mounted, beside it is the catch tank for the vacuum pump & beside that is the catch can for the glide
i was thinking that i should of mounted the catch tank for vac pump to the engine for when i run the engine on the dyno but as i had a hole in the firewall that had to be filled the tank got mounted were it is
regards
rod
 Post Posted: Sat Nov 22, 2008 4:42 am
more of the driveline pictures can be found here
http://s5.photobucket.com/albums/y172/r ... ?start=all
let me know what you think
regards
rod
 Post Posted: Sat Nov 22, 2008 8:09 am
that thing looks friggin sweet man. good luck with it
 Post Posted: Sat Nov 22, 2008 8:33 am
WOW!!!.....That car is over the top nice,I would be proud just to say I worked on it let alone OWNING it,you have done a very nice job and should be extremely proud of your accomplishment.
 Post Posted: Sat Nov 22, 2008 11:51 am
Really great work. I know what you mean about my laziness =; I feel the same way. When do you plan on racing it?
 Post Posted: Sat Nov 22, 2008 12:08 pm
SWEEEEEEEEEEEEEEEEEEEEEEEET =D>  =D>  =D>
"GASSERS ARE A GAS"
 Post Posted: Sat Nov 22, 2008 6:33 pm
It's looking real "Fast" Rod \:D/  \:D/  \:D/  Nice job for sure!!!!
But There is one thing I don't like and that is where you put the trans cooler.
If you pick up one rock with that front tire and it gets thrown up into that cooler and pokes a hole in it your going for a wild ride into the other lane O:)  O:)  IMO........ :-#
 Post Posted: Sat Nov 22, 2008 7:40 pm
thanks guys much appreciated
i palned on racing it a couple of weeks ago & knew that it wasnt going to happed & i think thats why i walked away from it
that & the fact that our Aussie dollar turned to crap & i had a lot of money out in parts that i bought in for other racers down here & didnt want to throw any more at it given the situation here
i was ready to purchase the last 3 items i need to complete the car being a set of Pro Jacks, Mark Williams Diff Centre & a Racepac Data Logger, at the time it would of cost around AU$13,800.00 landed here & now the dollar has turned to crap those same parts are closer to AU$20500.00
given that i had that money out layed in parts for other racers from down here i guess you can see why i walked away from it fo a couple of weeks
regards
rod
 Post Posted: Sat Nov 22, 2008 7:46 pm
hi Barry
i know what you mean but i looked at several different options before i mounted it & decided on my original thought of were it is now
to mount it under the back ment that i had lines running all the way down to the car underneath, lines that could easly get damaged & not show up until it was to late
i even looked at putting it in front of the radiator but as i am a little tight on room there & didnt want to run the lines down the front of the chassis rail either
my only option was to mount it as pictures & as you can see i have left the core raw aluminum to shop up any signs of weeping so i can get it bofore something goes wrong
the core is mounted on double sided rubber insulators to keep it off the fire wall so air will run through it & i didnt want any chance of it cracking due to flex in the firewall
regards
rod
 Post subject: Hey Rod
 Post Posted: Sat Nov 22, 2008 8:50 pm
Wow thats a very cool ride Rod \:D/  \:D/  \:D/
almost as cool as the Golf ball polisher  =;  =;  =;  =;  =;  :-$
Royz
You dont have to be pretty to go Really FAST
http://users.glowfoto.com/dnewnova
Think about your "Dash"
http://www.simpletruths.com/dash/index.html
 Post Posted: Sat Nov 22, 2008 10:57 pm
Rod,
Do you have anything to keep the engine from moving front to rear?
